Guess the problem I had get $10.00
- gpz1170
Re: Guess the problem I had get $10.00
16 Apr 2014 17:19
would it have anything to do with a piston ring? one not in the ring land correctly.
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- Powerstroke_fan
Re: Cam Timing Issue
16 Apr 2014 17:20 - 16 Apr 2014 17:22
I wasn't guessing on that, I was just telling you to make sure its installed before rotating. I forgot to snug my tensinor down before rotating my motor over by hand, it jumped a tooth on me. Luckily I caught it before I did any damage. That's why I always double check everything. But the on/off clicking has me wondering? makes me think valves hitting. :dry:
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 16 Apr 2014 17:22 by Powerstroke_fan.
- 4TheKZ1000
16 Apr 2014 17:21gpz1170 wrote: would it have anything to do with a piston ring? one not in the ring land correctly.
no......hint......has to do with cam chain.
- Powerstroke_fan
16 Apr 2014 17:21
He said it wasn't a mistake with install.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
16 Apr 2014 17:23Powerstroke_fan wrote: He said it wasn't a mistake with install.
everything was installed correctly,...........hint....... I changed something that caused a problem.
- 4TheKZ1000
- Powerstroke_fan
16 Apr 2014 17:25 - 16 Apr 2014 17:25
forgot to skip the first pin on the 28 count. or didn't have marks lined up correctly, front level with top the head, and the exhaust cam mark on 28th pin? how can it be cam chain related, but not a mistake during install?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 16 Apr 2014 17:25 by Powerstroke_fan.
- turboking
installed the wrong cam chain.......... :blink:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
Last edit: 16 Apr 2014 17:25 by turboking.
- Powerstroke_fan
16 Apr 2014 17:26
cams need retimed from new chain?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
16 Apr 2014 17:27turboking wrote: installed the wrong cam chain.......... :blink:
no, install was correct but for one upgrade I did that caused engine to bind.
- 4TheKZ1000
16 Apr 2014 17:28Powerstroke_fan wrote: cams need retimed from new chain?
no, not that.
- Powerstroke_fan
16 Apr 2014 17:30
new bigger cams?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
