Guess the problem I had get $10.00
  • 74ullc
  • 74ullc's Avatar
Re: Guess the problem I had get $10.00
16 Apr 2014 15:55
#629261
You left your He-Man action figure in one of the cylinders?
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
16 Apr 2014 15:56
#629262
Chain is jammed in front side of the crank below the guide. Crank must be able to spin freely while pulling the chain tight and installing the exhaust cam, but held in correct position with hand-tension pulling on the chain at the back...that was the hold-up with mine. :)
Good luck!
1982 KZ1100-A2
  • 74ullc
  • 74ullc's Avatar
16 Apr 2014 15:56
#629263
You forgot your engine is the Australian model and the engine rotates backwards?
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
16 Apr 2014 15:57
#629264
74ullc wrote: You forgot your engine is the Australian model and the engine rotates backwards?
Its a tough one.....don't think it will be guessed .
  • Nessism
  • Nessism's Avatar
Re: Cam Timing Issue
16 Apr 2014 15:57
#629265
4TheKZ1000 wrote:
Nessism wrote: Forgot to release the cam chain tensioner?
No.......The cam chain tensioner is ape manual and is off bike.
How can you turn the engine over without the cam chain tensioner installed?
  • 4TheKZ1000
16 Apr 2014 16:02
#629266
daveo wrote: Chain is jammed in front side of the crank below the guide. Crank must be able to spin freely while pulling the chain tight and installing the exhaust cam, but held in correct position with hand-tension pulling on the chain at the back...that was the hold-up with mine. :)
Good luck!
no, but gr8 guess.
  • 74ullc
  • 74ullc's Avatar
16 Apr 2014 16:02
#629267
You forgot to install the wired George coil mod?
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • 4TheKZ1000
16 Apr 2014 16:04
#629269
just turning it over with a wrench off of advancer nut right side.
  • 4TheKZ1000
16 Apr 2014 16:06
#629270
74ullc wrote: You forgot to install the wired George coil mod?
No have mod installed.
Attachment 0101024x826.jpg not found
  • 74ullc
  • 74ullc's Avatar
16 Apr 2014 16:07
#629271
You left string in the cylinders to hold the valves up? That's actually a serious guess.....I think?
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • Nessism
  • Nessism's Avatar
16 Apr 2014 16:08
#629272
If you try to turn over the engine without a cam chain tensioner taking up the slack, the chain will bunch up around the crank and bind it, or the cams will jump time and you risk bending valves.
  • 4TheKZ1000
16 Apr 2014 16:10
#629273
you could be right....not the problem.
