Guess the problem I had get $10.00
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
16 Apr 2014 13:46 - 16 Apr 2014 15:56
#629235
Well, getting engine put together.
Set 1 and 4 to top dead center mark on advancer..
I pulled chain tight around crank.
slipped in cams and lined up marks
Set chain / sprocket at 28th pin on chain
Its kinda hard to put cam caps on due to cam lobe pressing on bucket. I guess this should happen.
All went pretty easy. I then went to rotate engine forewards and it is bound up. The engine will spin backwards but is stiff and made a clicking sound off and on????
I cant seem to figure it out.
Last edit: 16 Apr 2014 15:56 by 4TheKZ1000.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Cam Timing Issue
16 Apr 2014 14:26 - 16 Apr 2014 14:42
#629242
did you install and adjuster the tensior and upper idler gear?
1977 KZ 1000 work in progress
Last edit: 16 Apr 2014 14:42 by Powerstroke_fan.
  • 4TheKZ1000
16 Apr 2014 15:26
#629250
DUMB-AZZ spence did something that caused it ........ Can you tell me what it was?
I will be taking your guesses on what was wrong until 9pm eastern time tonight.
If no correct guess by 9pm, I will spill the beans.
The correct guess will get $10.00 via PayPal from me.
Has to be what it was, not almost what it was......... :laugh:
  • 4TheKZ1000
16 Apr 2014 15:32
#629252
Powerstroke_fan wrote: did you install and adjuster the tensior and upper idler gear?
Nope did these things......not it
  • pete greek1
  • pete greek1's Avatar
16 Apr 2014 15:40
#629253
I know, You forgot to adjust da mirrors !! :laugh: :woohoo: :laugh:
  • Powerstroke_fan
16 Apr 2014 15:47
#629254
I cant think of what it could be that would allow it to turn backwards but not fowards
  • Troyn
  • Troyn's Avatar
Re: Guess the problem I had get $10.00
16 Apr 2014 15:47
#629255
The bike was in gear?
1983 kz750 ltd shaft, 4-cyl, stock everything :)
  • Nessism
  • Nessism's Avatar
  • 4TheKZ1000
16 Apr 2014 15:52
#629257
Troyn wrote: The bike was in gear?
no, chain and output shaft gear are off bike.
  • 74ullc
  • 74ullc's Avatar
16 Apr 2014 15:53
#629258
First thing I thought of too but I'm guessing the motor is out of the bike so engine would still turn over.
Probably has something to do with the blood moon....or....
Did you have the transformation synch gear cog installed and timed to the frequency transducer? Is the rubber band too tight around the sonic blast generator?
That's what I would check first.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • 4TheKZ1000
16 Apr 2014 15:53
#629259
Nessism wrote: Forgot to release the cam chain tensioner?
No.......The cam chain tensioner is ape manual and is off bike.
  • 4TheKZ1000
16 Apr 2014 15:54
#629260
pete greek1 wrote: I know, You forgot to adjust da mirrors !! :laugh: :woohoo: :laugh:
Drink one for me Pete........ :P
