turbo time....
- jeffasaki
Re: turbo time....
24 Oct 2012 20:19
i use a blow off valve on my 84 750 turbo
it greatly reduces turbo lag
when you go from a wot condition to closed throttle and back to wot again
lets the turbo kinda keep a full head of steam so its not trying to spool up against a already pressureised chamber
plus it sounds cool as hell
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- ramtough_63
Re: turbo time....
24 Oct 2012 20:23wow! that bike makes me wanna cry I think im just gonna give mine to my neihbor and start collecting cans
beautiful bike man
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- racer54
Re: turbo time....
25 Oct 2012 02:38 - 25 Oct 2012 02:41
I believe you only use a blow-off valve on a blow-thru system. You can't use it on a draw-thru as it will open the intake plenum and you won't build any pressure. A blow-ff valve and waste-gate are two different things to accomplish different things. Waste gate regulates boost while a blow-off valve relieves pressure in intake to allow turbo to spool down without going against pressure in intake after closing throttle.
Last edit: 25 Oct 2012 02:41 by racer54.
The following user(s) said Thank You: wireman, lushbaugh
- wireman
Re: turbo time....
25 Oct 2012 02:57Giggitty,giggitty!
- lushbaugh
- everybodys a pro......
Re: turbo time....
28 Nov 2012 01:50
slowly collecting parts will be ordering studs and main cap etc this week. gathered up all my aero fittings, thinking about running either airplane braided line or bent aluminum tube and polishing also got one of these...flows 100gph and filte
rs down to 40 microns..
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- kzz1king
Re: turbo time....
28 Nov 2012 23:58Do you have a low profile crank case breather? If not remind me to send mine.
Wayne
Home built KZ1000 turbo setup
- lushbaugh
Re: turbo time....
29 Nov 2012 02:25
i do not wayne... didnt think about that doh! anything else i may need?
- kzz1king
Re: turbo time....
29 Nov 2012 13:30I will send you one with the rest., I think I have a tall one I can use with my carbs.lushbaugh wrote: i do not wayne... didnt think about that doh! anything else i may need?
Wayne
- lushbaugh
Re: turbo time....
29 Nov 2012 14:10
if not i can ship you mine...
- lushbaugh
Re: turbo time....
06 Dec 2012 02:15
how are you guys handling the issue of pulling out timing....
- donthaveakawman
Re: turbo time....
06 Dec 2012 04:49With a cold air intake you might be better off, to use a vacuum operated carburetor with boost it seems too complicated. Yeesssssss.lushbaugh wrote: im peicing together a turbo kit and fabbing what i can myself. fuel pump from car aero fittings ive been collecting car boost guage etc. im looking for as many pics and pointers as possible from anyone who cares to share. including but not limited to carb info motor spec anything relevent even gearing. im very formilliar with the car side of forced induction just looking to learn and be inspired so lets get the ball rolling!
- donthaveakawman
Re: turbo time....
06 Dec 2012 04:53 - 06 Dec 2012 04:574TheKZ1000 wrote: best spent money for a performance streetable build is a turbo setup...have to know what you doing though......as for Mr.Turbo....arent they the only kit out there...?
www.mrturbo.com/turbo-sys/kawasaki/kz/kz.html
Mr. Turbo web info
Power Gains:
Boost / Small CC (900-1000) / Big CC (1200-1400)
10lbs / 140 hp / 170 hp
20lbs / 200 hp / 230 hp
30lbs / 280 hp / 310 hp
With the increasing use of chat rooms and an endless number of places to get information these days, be careful, much of it is bad information. Every Horsepower number claimed by us on our website, over the phone, or any advertisement is based on “rear wheel” numbers from our DynoJet 250 dyno. Rear wheel numbers, at the pavement, confirmed by other dynos around the world, no exaggerating, no “pie in the sky”, and no bragging… just fact.
by the time you get done paying for that you could buy a used zx14 ninja that already has upwards of 170 horsepower, and if the police catch you using (the power)it you will probably need the helmet for what they will do to you.
My first car was factory rated at 81 horsepower, 4 speed, front wheel drive, and 2000 lbs(rough estimate)capable of 105 mph or so, why risk your life. also had seatbelts.
Last edit: 06 Dec 2012 04:57 by donthaveakawman.
