turbo time....
- lushbaugh
- everybodys a pro......
turbo time....
14 Oct 2012 21:25
im peicing together a turbo kit and fabbing what i can myself. fuel pump from car aero fittings ive been collecting car boost guage etc. im looking for as many pics and pointers as possible from anyone who cares to share. including but not limited to carb info motor spec anything relevent even gearing. im very formilliar with the car side of forced induction just looking to learn and be inspired so lets get the ball rolling!
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- 4TheKZ1000
Re: turbo time....
14 Oct 2012 22:14Please Log in or Create an account to join the conversation.
- lushbaugh
Re: turbo time....
14 Oct 2012 22:37
ive had an eye on that but i dont have all the money at once. thats why im peicing a setup together. its an all winter project maybe two winters to accumulate all the parts.
- kzz1king
Re: turbo time....
14 Oct 2012 23:18
I went that route. Never got all the bugs worked out and am losing interest. I have pics on here in the project section. I will see if I can find it for you.
Wayne
Wayne
Home built KZ1000 turbo setup
- kzz1king
Re: turbo time....
14 Oct 2012 23:21
- lushbaugh
Re: turbo time....
14 Oct 2012 23:40
kzz1king would you consider selling your setup cause i can get a jump on this if i start there. it just needs love and attention your very close all you need is most likely a wastegate adjustment or seals. you nailed it tho.
- Nebr_Rex
Re: turbo time....
14 Oct 2012 23:56 - 14 Oct 2012 23:57lushbaugh wrote: im peicing together a turbo kit and fabbing what i can myself. fuel pump from car aero fittings ive been collecting car boost guage etc. im looking for as many pics and pointers as possible from anyone who cares to share. including but not limited to carb info motor spec anything relevent even gearing. im very formilliar with the car side of forced induction just looking to learn and be inspired so lets get the ball rolling!
The Wireman cometh :woohoo:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 14 Oct 2012 23:57 by Nebr_Rex.
- wireman
Re: turbo time....
15 Oct 2012 01:10Attachment popcorn_2012-10-15.gif not found
- lushbaugh
Re: turbo time....
15 Oct 2012 01:56
lol so i hear wireman is a turbo lover. please share wisdom man. im always down to learn.
- wireman
Re: turbo time....
15 Oct 2012 09:49
Im trying to wake up so I can go go get more work done before my trip,Im only hitting on 1 of 4 cylinders right now cant think that hard at the moment. :sick: :woohoo:
When I get home tonight Ill check in and see whats happening.
:laugh:
Attachment mqdefault.jpg not found
:laugh:
- Jeff.Saunders
Re: turbo time....
15 Oct 2012 10:16
You certainly need to start the build with the turbo in mind.
Cut corners and you'll be doing it again...
Here's my setup:
1200cc turbo pistons
ATP Turbo kit with RayJay 370 turbo
electric fuel pump
Welded crank
main bearing support plate
HD cylinder and main bearing studs
Modified oil pan with deep sump extension
Oil pump optimized and modified for the deep sump pickup
MRE lockup clutch (the only way to eliminate clutch slip and an aching wrist from pulling in the clutch lever with HD clutch springs)
42mm HSR carb
Dyna 2000 ignition with retard map driven by boost sensor.
K&N Air/Fuel Sensor with readout.
Back in 2001 when I picked up the bike, it was newly rebuilt - but it had an awful Mikuni 2-circuit carb (snowmobile carb) that had no mid-range control - I dumped that for the HSR 42 fairly quickly. I soon found the previous owner skimped on the engine rebuild as the head gasket started leaking - after pulling the head off, I found stock cylinder studs - sigh.... The old Gerex igntion generated a fat spark, but used the mechanical advancer - no real way to control the retard so he had a water/alcohol injection system on the bike to help manage detonation issues, so that all went and was replaced with the Dyna 2000. THe clutch was an extra-disk clutch - but even with the stiffest springs would slip under heavy load in 3rd gear. That was pulled out and replaced with stock style clutch plates and an MRE lock-up clutch - A much lighter clutch action and it never slips now.
I only have the bike running 7-8 lbs of boost - but even with that an slightly tall gearing the bike will power wheelie in 2nd gear and you can feel the wheel going light in 3rd gear.
Here's my setup:
electric fuel pump
Welded crank
42mm HSR carb
www.z1enterprises.com
Z1 Ent on Facebook,
- Puffin
Re: turbo time....
15 Oct 2012 13:48
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
