turbo time....
  • lushbaugh
  • lushbaugh's Avatar Topic Author
  • everybodys a pro......
Re: turbo time....
21 Dec 2012 11:16
#563907
naked fun, as of now i have a 1105 kit on stock sleaves but if i can find something in time to swap it out i will. my turbo is a t25 internally wastegated garret with carbon seals installed.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • lushbaugh
Re: turbo time....
21 Dec 2012 11:19
#563908
if i could swap and barter and buy a sleaved cyl up to 1200 id get that to keep, im using a j head that will drop compression. what turbo do you have ?
  • lushbaugh
Re: turbo time....
21 Dec 2012 11:20
#563909
also thanks for that awesome completely irrelevant post as usual donthavakawman
  • NakedFun
  • NakedFun's Avatar
Re: turbo time....
21 Dec 2012 12:07
#563914
It is an HX25, non-wastegated. It was one I built for a project that never got off the ground. I fear if I keep the turbo, I am afraid I'll use it on my KZ project!! :woohoo:
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: turbo time....
21 Dec 2012 12:22
#563916
NakedFun wrote: It is an HX25, non-wastegated. It was one I built for a project that never got off the ground. I fear if I keep the turbo, I am afraid I'll use it on my KZ project!! :woohoo:
Cory
DO IT CORY, DO IT :evil: :evil: :evil:
  • NakedFun
  • NakedFun's Avatar
Re: turbo time....
21 Dec 2012 13:50 - 21 Dec 2012 13:51
#563926
Cory
But then I am going to have to do a blow through system because it is freakin' cool.....and that will take more time to finish the bike......and I'll end up probable killing myself in the process... :P
I finished running your breathing lines. The one variable I put in had to be fudged, because without testing, I can't be precise. I gave you a system (Think head ports, intake system, dynamic compression, etc...) volumetric efficiency of 70%. This is based on a number of engines I have done that were spark ignited. You have a very short runner, and figuring you will use a later J head, I think the best you would do on the combo would be 77%. With that being said, and using a ambient temp of 76 F and at sea level (14.7 PSIA) the breathing lines layout with these point of running RPM.
1800rpm = 1.834 lbs/min or 24 cfm (corrected for the above factors)
3000rpm = 3.057 lbs/min or 41 cfm
4200rpm = 4.279 lbs/min or 58 cfm
5500rpm = 5.604 lbs/min or 76 cfm
6500rpm = 6.623 lbs/min or 89 cfm
7500rpm = 7.642 lbs/min or 103 cfm
8500rpm = 8.661 lbs/min or 117 cfm
9500rpm = 9.679 lbs/min or 131 cfm
10500rpm = 10.698 lbs/min or 145 cfm
I selected some of these rpm points as they may be common operating points. Holset uses Holset Flow Parameter, but I provided it in CFM as the majority of aftermarket turbos commonly provide compressor maps in that format.
Cory
1976 Kawasaki KZ900
Last edit: 21 Dec 2012 13:51 by NakedFun.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
Re: turbo time....
22 Dec 2012 13:43
#564069
As I said earlier, No disrespect intended! But, you leave an open ended comment, You will get it used against you around here and it will all be in fun!
Les
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: turbo time....
22 Dec 2012 14:37
#564083
Lush is going to kick some asses for muckin up his thread with all this jiberish.....turbo talk only please :ohmy: :ohmy: :woohoo: :woohoo: :woohoo: :woohoo:
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
Re: turbo time....
23 Dec 2012 14:30
#564263
What you need is a GPz750. Then add a front mounted turbo, fuel injection, upgrade the engine internals....no, wait....Kawasaki already did that :laugh:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • donthaveakawman
  • donthaveakawman's Avatar
Re: turbo time....
23 Dec 2012 15:25 - 23 Dec 2012 15:30
#564278
a while back on www.therangerstation.com/tech_library/Turbos.html I pondered upon a saying. I can't remember where it was this saying that I found was, but it was funny I remember that.
"the harder she blows the faster she goes"
but now all this jibberish and I don't see one finished bit of work. sounds like a bunch of talk to me.
... kawkaw....sakisaki...
Last edit: 23 Dec 2012 15:30 by donthaveakawman.
  • 4TheKZ1000
Re: turbo time....
23 Dec 2012 15:30 - 23 Dec 2012 15:34
#564280
Another cleanup needed on thread turbo time please...... :dry:
Attachment 12065697902136786863pitr_red_arrows_set_1_svg_med.png not found
Last edit: 23 Dec 2012 15:34 by 4TheKZ1000.
  • wireman
  • wireman's Avatar
Re: turbo time....
23 Dec 2012 16:19
#564290
Im just waiting for a big truck(company name here)to deliver a bunch of stuff in next week or so,then youll see some progress.
Im spending next couple days in the basement working on some pieces Ive already been working on that will make it on to his project B)
