turbo time....
  • lushbaugh
  • lushbaugh's Avatar Topic Author
  • everybodys a pro......
Re: turbo time....
11 Dec 2012 08:33
#562498
thanks les, guess the dyna s is gone lol
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: turbo time....
11 Dec 2012 13:01 - 11 Dec 2012 13:07
#562529
lushbaugh wrote: so i will try to ask again, whats the best way to retard the timing, ive heard about hobbs switch but it is non adjustable etc....
The Dyna 2000 is the best setup for this. On my bike, I have a boost pressure switch that activates the retard settings on the Dyna 2000. There's a separate circuit on the Dyna 2000 harness that trips the retard settings on the igntion map.
With the Dyna 2000 you can use the 3 turbo retard settings preprogrammed in the control module, or with the additional CurveMaker software, you can remap the ignition to retard when you want it to.
We've experimented on my turbo bike and it's much better having the retard boost sensititve rather than determined by RPM.
I've experimented with the retard settings between 8 and 12 degrees - but it really depends on the temperature and humidity which works best.
Here is the link to our facebook page with the turbo - you'll see the boost switch on the RH side of the bike
Z1 Ent Turbo Album on Facebook
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Last edit: 11 Dec 2012 13:07 by Jeff.Saunders. Reason: added link
  • lushbaugh
Re: turbo time....
11 Dec 2012 13:03
#562530
very cool i will have to get one. im not comfortable with just a switch or just clocking back the timing
  • lushbaugh
Re: turbo time....
20 Dec 2012 19:31
#563855
racer54 wrote:
1977 KZ turbo...old ATP turbo system, 1200cc, stretched 6" over, .340 cams, HSR42 carb....here are a couple pictures...
i love this bike, whaat seat is that?
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Moderator
Re: turbo time....
20 Dec 2012 20:06
#563861
Home/custom made would be my guess
  • NakedFun
  • NakedFun's Avatar
Re: turbo time....
20 Dec 2012 22:34
#563872
Lush,
Do you have a turbo yet? If so are you going to run and external or internal waste gate. I may have a new turbo sitting around that might do the trick if you are going to at least a 1200. I can be useful on the topic of turbos and turbo support systems. In a former life I was a turbocharger engineer for Holset Turbos. I did all the race applications and one offs for the company in North America. If you have any questions, feel free to ask.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • wireman
  • wireman's Avatar
Re: turbo time....
20 Dec 2012 23:18
#563874
Ive been trying to steer him into something between a 1015-1075 motor for his first turbo project,I think that's plenty of motor to get him in trouble with a little boost behind it. B)
Theres plenty of time for the 1200 turbo once he scares the shit out of himself working the bugs out of this system and learns how to ride it! :woohoo:
We could defifinately use some help sizing up the system for this smaller motor though,with the emphasis being on affordable here.
Yeah I know,what a contradiction of terms performance/affordable! :woohoo:
  • NakedFun
  • NakedFun's Avatar
Re: turbo time....
21 Dec 2012 00:07
#563878
That is fine. I can run my airflow program on that motor combo and build some breathing lines so they can be laid out on some compressor maps. I'll grab that turbo this weekend and see what it is suitable for. I'll donate it to the cause if it works.
Cory
1976 Kawasaki KZ900
  • lushbaugh
Re: turbo time....
21 Dec 2012 11:16
#563907
naked fun, as of now i have a 1105 kit on stock sleaves but if i can find something in time to swap it out i will. my turbo is a t25 internally wastegated garret with carbon seals installed.
  • lushbaugh
Re: turbo time....
21 Dec 2012 11:19
#563908
if i could swap and barter and buy a sleaved cyl up to 1200 id get that to keep, im using a j head that will drop compression. what turbo do you have ?
  • lushbaugh
Re: turbo time....
21 Dec 2012 11:20
#563909
also thanks for that awesome completely irrelevant post as usual donthavakawman
  • NakedFun
  • NakedFun's Avatar
Re: turbo time....
21 Dec 2012 12:07
#563914
It is an HX25, non-wastegated. It was one I built for a project that never got off the ground. I fear if I keep the turbo, I am afraid I'll use it on my KZ project!! :woohoo:
Cory
1976 Kawasaki KZ900
