Replacing Valve Stem Seals without pulling head
  • pctech101
  • pctech101's Avatar Topic Author
25 Jun 2011 22:30
#459365
Got an 83 kz1100-L1
Tore her down and put new rings, new cam chain & guides, had valve job done @ machine shop. I supplied valve seals from my gasket set.
Problem. 200+ miles since reassembled. Burns quart of oil in 50+ miles. Fouls #1 sparkplug about every 50 miles. Plugs 1,2,3 all show signs of burning oil, 4 is clean. Compression is 150 on all 4. Havent done leak down, cant afford right now.
All the reading i have done leads me to believe it was those damn valve seals from gasket set. I have ordered Vitons. I have read through out many forums that you can use air to keep valves up, and replace seals without pulling head. Can it be done without air, using rope threaded through spark hole and turning to TDC or something similar? Any tips and woes?
  • MFolks
  • MFolks's Avatar
Re: Replacing Valve Stem Seals without pulling head
25 Jun 2011 22:35
#459366
If Larry Cavan isn't too busy and sees this, he might offer advice.
25 Jun 2011 23:16 - 25 Jun 2011 23:18
#459371
Imperfect valve seals often result in more exhaust smoke before the engine attains normal operating temperature and less exhaust smoke at normal operating temperature.
Could be wrong, but thinking imperfect valve seals wouldn't cause burning a quart of oil every 50 miles.
A leak down test likely won't diagnose broken or improperly installed oil rings, which might be causing the reported issues.
Good Fortune! :)
Last edit: 25 Jun 2011 23:18 by Patton.
  • pctech101
26 Jun 2011 00:06 - 26 Jun 2011 00:31
#459379
Lets entertain my grand lure that it is crapy valve seals that are the problem.
She love to smoke during engine braking/downshifting, at idle at red light and you roll throttle a couple times. She'll idle and not smoke. She'll idle and barely smoke. Drive the dogsh!t out of her up to 100Mph, doesnt smoke to much. Just the other day when she burnt a quart in about 50miles, she started smoking heavily while running 75, dropped speed to 60, didnt change much, got to light, started up again and she didnt smoke that heavily again. Nothing is static except that she burns oil. She smokes how she wants to. If it was oil rings, would there not be a more uniform burning going on?
Last edit: 26 Jun 2011 00:31 by pctech101.
  • APE Jay
  • APE Jay's Avatar
26 Jun 2011 03:54
#459395
Sounds like it might be pulling oil down the outside of the intake guides.
  • nads.com
  • nads.com's Avatar
26 Jun 2011 04:14
#459398
APE Jay wrote: Sounds like it might be pulling oil down the outside of the intake guides.
Now I know your old, and it's late, but how is that possible o mysterious one? :blink:
Are you saying without saying, in some form of riddle, the guide is loose or cracked or what??
Say it mann sayy it!
Can we get a drum roll for Jay? bbbbbbbbb booom!
Thank you, Thank you
  • Motor Head
  • Motor Head's Avatar
26 Jun 2011 09:46 - 26 Jun 2011 10:22
#459412
Yes you can change the seals out without pulling the head, if you have the correct tools. Depending on whether or not you have the right kind of spring compressor. Something like this:
cgi.ebay.com/ebaymotors/Universal-OHC-OH...&hash=item3a6758443d
That much consumption sounds more like a oil ring issue, like Patton said.
If you need to buy another spring compressor, better to just take off the head, so then you can be ready to pull the cylinders off when the valve seals look OK. You can still fit the Teflon ones then.
Last edit: 26 Jun 2011 10:22 by Motor Head.
  • ELCouz
  • ELCouz's Avatar
26 Jun 2011 15:01 - 26 Jun 2011 15:05
#459469
Looks like somebody pinched the very thin and delicate oil rings AND/OR misaligned the oil rings :whistle:
btw, did you get the cylinders honed when put the new rings ?
Maybe you rings never seated properly...possibly out of specs cylinders ?
Hope this helps!
regards,
laurent
EDIT: don't forget this
:whistle: :whistle: :whistle: :whistle:
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 26 Jun 2011 15:05 by ELCouz.
  • bountyhunter
  • bountyhunter's Avatar
26 Jun 2011 15:13 - 26 Jun 2011 15:16
#459472
Patton wrote: Imperfect valve seals often result in more exhaust smoke before the engine attains normal operating temperature and less exhaust smoke at normal operating temperature.
You are correct. On my 750, I had one seal so bad it had torn the top of the seal completely away. It did foul the plug, but very little oil consumption.
I would bet on a damaged/broken/collapsed ring.
Last edit: 26 Jun 2011 15:16 by bountyhunter.
  • ELCouz
  • ELCouz's Avatar
26 Jun 2011 15:22 - 26 Jun 2011 15:27
#459476
chance that you are getting brand new seals with imperfection are low!
/me thinks butched valve job! :dry:
Maybe an incorrectly installed seals or even broken or missing valve seals could cause to leaks and suck oil around the valve guide a lot !
Beside that you could have a cracked head (oil channel seepage)or bad rings ...
i think thats it!
Last edit: 26 Jun 2011 15:27 by ELCouz.
  • pctech101
26 Jun 2011 15:58 - 26 Jun 2011 16:25
#459482
Well i personally dont have a clue.
Yes the cylinders were honed for new rings.
I have not checked/adjusted valve clearance yet, can that let it burn oil too?
It wasnt burning anything before teardown so i highly doubt my head has a crack.
Last edit: 26 Jun 2011 16:25 by pctech101.
  • ELCouz
  • ELCouz's Avatar
26 Jun 2011 16:02 - 26 Jun 2011 16:04
#459484
No but too much clearance cam lobe will slap the valve (noise and possibly pounding the valve seat which is not good) and not enough clearance will make the valve not closing properly (can also overheat the valves)
For me i would take the time and tore down the engine again to check everything again because its not normal something f**ked up... patience is a virtue i've read that somewhere :)
Last edit: 26 Jun 2011 16:04 by ELCouz.
