- Thank you received: 1
Clutch issue/Checking Timing
- BIGKEVIN
21 Dec 2010 15:38 #418115
by BIGKEVIN
1976 KZ900
2006 ZX6R
Replied by BIGKEVIN on topic Clutch issue/Checking Timing
Went back out and did the clutch adjustment that Old Man Rock suggested, but still did not fix my problem. I took the clutch pack back out and looked everything over and they looked good. Put them back in and did the clutch adjustment again and it is working good now. The only problem that I seem to have now is that when the bike is running and in gear, it pulls for and is hard to get into neutral. I think a little more adjusting will correct this.
Thanks to ALL for the help thus far.
1976 KZ900
2006 ZX6R
- Thank you received: 2098
21 Dec 2010 23:58 #418170
by Patton
Replied by Patton on topic Clutch issue/Checking Timing
It's possible that the threaded area of the clutch actuator mechanism is sticking from lack of lube or old impacted grease, and thereby failing to provide its full designed range of movement. See image below.
And such sticking might also disallow proper clutch rod adjustment.
If not already done, would disassemble the clutch actuator mechanism, and clean and re-grease the threads on parts 4 and 6.
When reassembling, assure that the clutch actuator mechanism is easily moving through its full range of motion when the handlebar clutch lever is being squeezed and released.
And assure that the clutch actuator mechanism is correctly assembled and correctly attached in its position onto the sprocket cover.
[Click on image to enlarge view.]
