- Thank you received: 2098
Clutch issue/Checking Timing
I just measured all 10 of the clutch disks and none of them meet the minimum of 1.27". I don't know what the previous owner did, but I am wondering if he ordered clutch disk and they were machined thinner so more disks were installed. I have order the disks from Z1 and they should be here in a couple of days.
That's likely a typo, but to confirm, the 1.27" is the clutch spring free length.
While anything's possible, am doubtful about existing smooth steel plates being stock plates having been machined thinner.
- BIGKEVIN
- Thank you received: 1
1976 KZ900
2006 ZX6R
- P21
- Thank you received: 34
both friction and metal plates
springs?
all this work and no new springs would be a shame.
this part is often over looked and them poor bitches are always under tension.
this a major part of what makes the bike go forward
Kawasaki KZ 1000 Police (2002) P21
- BIGKEVIN
1976 KZ900
2006 ZX6R
- BIGKEVIN
1976 KZ900
2006 ZX6R
- P21
adjust your cable slack?
final adjustment at star wheel?
start bike up and hold front brake on. i would hate to see you slam in to the garage wall.....hehehe put the bike in gear and ride it?
let us know what the hell is up on this?
these guys gave you enough info to rebuild the damn bike,but if dont have a MANUAL shame on you!
The Manual is the Holy Bible to bike Fixing buy one!
sorry to be smart ass,but when people refuse to buy the BOOK it pisses me off.
good luck on your bike
- BIGKEVIN
1976 KZ900
2006 ZX6R
Would try with 1/4" gap....turned the adjusting screw until it tightened and then turnd it counterclock wise a 1/2 turn or so and tightened up the nut. I tried adjusting the cable at the mid point and at the lever. No matter how I adjust it, the clutch adjusting screw only moves a tiny bit. How much is it supposed to move ?
Minimize free play of inner cable inside sheath (by adjustments at handlebar and mid-sheath).
When watching the screw while working the handlebar clutch lever, it's normal that the screw doesn't seem to be moving very much.
- BIGKEVIN
1976 KZ900
2006 ZX6R
Sprocket cover isn't pulling away from the engine as the handlebar clutch lever is being squeezed;
All sprocket cover screws are fitted and snugly tightened;
That male threads on screws are good;
That all female threads inside case are intact and not stripped;
Sprocket cover isn't damaged or cracked.
Yes.What do you mean by 1/4 inch gap ? Are you talking about turning the screw out 1/4 turn instead of a 1/2 turn ?
And if all else fails, might be desperate enough at this point to briefly test for effect with zero gap.
As known, the gap is to assure full engagement (closure of the plates) and thereby avoid slippage while riding.
