- Thank you received: 2098
Clutch issue/Checking Timing
Push rod isn't damaged, especially at the ends;
Ball bearing is present (hasn't been lost).
[Click on image to enlarge view.]
- P21
- Thank you received: 34
when you had the side cover off (where the clutch plates are)
did you even think about working the clutch (lever at handlebars) while this side cover was OFF and see if your presure plate was moving in or out ?????
just trying to help here.
Kawasaki KZ 1000 Police (2002) P21
- BIGKEVIN
- Thank you received: 1
1976 KZ900
2006 ZX6R
- BIGKEVIN
1976 KZ900
2006 ZX6R
- BIGKEVIN
1976 KZ900
2006 ZX6R
- MFolks
- Thank you received: 540
- BIGKEVIN
1976 KZ900
2006 ZX6R
- MFolks
- BIGKEVIN
1976 KZ900
2006 ZX6R
When I took the clutch cover off, the ball bearing was still in. How do you get the push rod out ? From the left or right side ?
The ball bearing is what the push rod pushes against.
The ball bearing comes out only after the push rod comes out, on the left side of the bike.
- MFolks
With the sprocket cover off, clean and inspect the throw out mechanism for the clutch push rod. Some wheel bearing grease(a small amount) is about all it needs now and then.
Look at the cable condition for signs of wearing/stretching too.
...took the push rod out. It had so much old oil and grim cake on it that I am thinking that it was being stopped from pushing the clutches....
got the sprocket covers off and took the push rod out --- the ball bearing will come out the same hole that the push rod came out of.
Be sure the ball bearing isn't omitted when reassembling.
When reassembling, the ball bearing goes in first, before the push rod.
While the push rod and ball bearing are removed, it's okay to spray some WD40 into the hole where the push rod and ball bearing came out from. As this should help clean and remove all the old oil and thick gunge inside the push rod passageway.
As earlier noted, examine the push rod carefully to assure it isn't bent, and that the ends aren't damaged. Also assure the ball bearing is in good condition.
