- Thank you received: 1
Clutch issue/Checking Timing
- BIGKEVIN
1976 KZ900
2006 ZX6R
- P21
- Thank you received: 34
sounds like you got too many plates going on in there.
just stick with STOCK set-up
and DONT forget NEW springs
Kawasaki KZ 1000 Police (2002) P21
- P21
7-steel plates @7.23 = 50.61
8-friction plates @4.82 = 38.56
5-springs @ total 13.82
so your total for plates only is =89.17 thats cheap considering the prices for newer bikes
so with plates and springs total 102.99 not bad
then you got all new stuff and good to go
just make sure you readjust your push rod set-up after this.
- BIGKEVIN
1976 KZ900
2006 ZX6R
- MFolks
- Thank you received: 540
- keith1
- Thank you received: 2
I'm just wondering why there were so many disks installed. I'll order the parts tomorrow.
its done for a couple of reasons...none of which really work.....APE sells an extra plate kit.....just go with your stock set-up when re-ordering....Timebomb(tim) has many 1320 passes on built motors with a stock clutch set-up....the key is adjusting it right.....
- BIGKEVIN
1976 KZ900
2006 ZX6R
- Thank you received: 2098
It's possible that a previous owner attempted to correct slippage by adding plates, when a simple push rod adjustment would have eliminated the slippage.
- BIGKEVIN
1976 KZ900
2006 ZX6R
Clutch spring free length
Standard 1.33" (33.8 mm)
Service Limit 1.27" (32.3 mm)
Friction Plate Thickness (Surface to Surface)
Standard .146" (3.7 mm) ~ .154" (3.9 mm)
Service Limit .134" (3.4 mm)
Friction Plate Warp
Standard < .006" (.15 mm)
Service Limit < .012" (.30 mm)
Steel Plate Warp
Standard < .008" (.20 mm)
Service Limit < .016" (.40 mm)
- P21
- BIGKEVIN
1976 KZ900
2006 ZX6R
