- Thank you received: 1
Clutch issue/Checking Timing
- BIGKEVIN
1976 KZ900
2006 ZX6R
- hocbj23
- Visitor
- BIGKEVIN
1976 KZ900
2006 ZX6R
- Thank you received: 2098
How do you change the oil on this bike ? On the other 2 bikes that I had, the oil filter was visable. Where is the oil drain plug and how many are there. Where is the filter located ? I don't see it in the Haynes manual.
[Click on image to enhance view.]
- BIGKEVIN
1976 KZ900
2006 ZX6R
- P21
- Thank you received: 34
but when you had oil drained you should of open the clutch cover(big round cover) and removed presure plate and springs and look at your clutch pac (friction-metal-friction-metal and so forth.
all it takes is some cooked plates and you have clutch drag and all that other stuff that the cable adjustment cant do.and push rod adjustment.
Kawasaki KZ 1000 Police (2002) P21
- BIGKEVIN
1976 KZ900
2006 ZX6R
- P21
the way its sounds i bet you your clutch plates are fried.
if you go inside clutch take your time and keep all parts in order of removal.
it sounds like a hard job,but its not
after you do this you will say shit that was easy!!
best of luck
- BIGKEVIN
1976 KZ900
2006 ZX6R
- P21
- BIGKEVIN
1976 KZ900
2006 ZX6R
- BIGKEVIN
1976 KZ900
2006 ZX6R
