KZ1K'S ENGINE PROJECT
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- PLUMMEN
- Thank you received: 104
- kz1k
the damn philleps head screw is a mother fucker to losten....i might just leave ittrianglelaguna wrote:
no doobie ash in cuts...lolgood job on the zip locks...i also put a small card in the bag with the label in sharpie...it seems the only one that ever rubs off the writing on the baggie is the one that i always need and cant remember it's location..index cards are great back up...if a yr goes by the memory will not be needed........blue painters tape and a sharpie is good for bigger parts wrap around a stud or bolt ect......
watch out for getting doobie ashes in that finger cut ...it burns
how do i remove this fking thing.
1978 KZ1000A2
- PLUMMEN
holds the spring for shifter linkage,worry about that after cases are cleaned upthis is what the spring was hooked up to. i noticed its slightly bent...is that ok?
- kz1k
once i remove the bolt in the pic...then what?kz1k wrote:
remove that bolt/pin,couldnt see the pin was still installed on other picturelol
1978 KZ1000A2
- PLUMMEN
- PLUMMEN
come on now think about it,pull really freaking hard and try not to bone out the rest of your damn fingers! :laugh:PLUMMEN wrote:
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- PLUMMEN
now soak the stripped down cases,pan,block and head down with simple green or 409 and head off to the car wash
