- Thank you received: 104
KZ1K'S ENGINE PROJECT
- PLUMMEN
are you using the threaded holes on bottem case to run bolts into to push on top case?
- kz1k
- You Cant Fix Stupid!
yes 2 on the front one in the back. the one in the back opens and the one on the left front too. not the right front though.are you using the threaded holes on bottem case to run bolts into to push on top case?
1978 KZ1000A2
- PLUMMEN
- kz1k
right side up....l/f......they are all out.kz1k wrote:
my manual isnt here yet.....i took out 25 bolts includint the 4 on the inside......the front right side of the motor is the only side that did not open. what am i missing?
Someone to weld the chunk back in you're going to break if you're not careful
Upside down...R/F would be where the 5 top case bolts are.
right side up...the right front is still fixed closed.
1978 KZ1000A2
- PLUMMEN
are you talking starter or clutch basket side of motor?
- porchev914
- Thank you received: 19
FRANKEN Z!
- PLUMMEN
- Old Man Rock
- Thank you received: 225
Joe... I don't know if you're just lazy, can't read, retarded or just plain stubborn.... :laugh: but here goes once again.... :whistle:
FOLLOW THE LINK AND DOWNLOAD THE Z1 OEM Service MANUAL... It's 98% the same for the KZ900 and 77/78 KZ1000 models...
It's Freaking FREE....
kzrider.com/index.php?option=com_docman&...d&gid=434&Itemid=108
It gives step by step instructions on how to split the cases... It even has PICTURES for you.... :pinch: :laugh:
Ah these damn kids these days are killin me... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- larrycavan
- Visitor
- larrycavan
- Visitor
- Old Man Rock
BTW... As for the rotor and clutch, leave it in for now, no need to diss-assemble to split cases....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kz1k
1978 KZ1000A2
