KZ1K'S ENGINE PROJECT
- kz1k
- You Cant Fix Stupid!
where do i start? do i send out the "bottom end' of the motor? (pistons/crank) i want to do this RIGHT! your opinions are important to me. this thread will be updated with pics and progress of before and after pics...thanks
1978 KZ1000A2
- kawsakiman
- Thank you received: 6
or send it to ape or fast by gast.
- kz1k
1 PSP-MTC-K1075 piston kit, complete with (4) forged aluminum pistons with 10.5:1 compression using stock camshafts, (4) sets of 72XC rings, (4) hard chromed wrist pins, ( teflon buttons sized for 72mm bore, (1) one piece fiber Cometic head gasket & (1) base gasket.
1 Boring
1 Refinish cylinder with baked on high temp silver paint
1 Cam chain guide
1 Press sleeves to reseat
1 Resurface cylinder
1 Valve Job with guides and seal
1 HD valve springs
1 Refinish head with baked on high temperature silver paint
1 Tach drive seal
1 Tach drive o'ring
1 Clearance for high lift cams
1 Resurface head
4 Remove and replace bottom exhaust studs for head surfacing
no shipping cost.....drop off, and pick up!
1978 KZ1000A2
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Dont pay them to paint it, just have it media blasted. Check out Larrys work: Cavanaugh Racing
Do it, just DO IT.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- TeK9iNe
If you are getting all that work done to the top end you might want to get the bottom looked at, I found that out the hard way.
Oh yeah, deffinately have the whole engine spec'd out, else you could be wastin alot of $$$
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- Thank you received: 104
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- DoubleDub
- Visitor
But seriously...any improvement in the top end should be accompanied by a review of what's below it. Are your gears in good shape? Is you oil pump good? Is your crank in good condition? If you're going with more power you may want to get the pin welded on the crank. Are your bearing shells in good shape?
Without verifying all this you could just be creating a bigger bomb.
- kz1k
As far as the bottom end goes, the only thing that I would do if it was my motor, is replace the cam chain.
The cam chain is always going to stretch.
The more it stretches, the further retarded in timing your camshafts get.
The cam chains that I have are heavy duty Tsubaki ($44.25).
The heavy duty chain is thicker than the stock chain and is also stronger.
It will stretch slower than a new stock chain.
If you like to do the occasional “trophy runâ€, then I would also suggest heavy duty valve springs ($52.95).
This makes the motor very forgiving in that you can have a bad day and miss a shift at high RPM and not damage the motor.
You need to tell me when you are coming so that I can be sure to be around.
I do not keep anything even resembling regular hours.
I can supply bottom end assembly/disassembly instructions if you need them.
Joe Hooper
1978 KZ1000A2
- PLUMMEN
You post the problems youre having with the bike,but when people tell you what to check you just ignore them and keep asking same question!
You give your bike to some guy you met on the internet to work on,then you panic because you think he stole your bike.
You get the bike back,we try and talk you through what to check and once again you ignore what people are saying.
You tear the head off your motor and we tell you how to check the valves for leaks and clean up the parts to save yourself some money by doing the grunt work,then you say its going to cost too much to do the head.
Then we find you a couple cheap used motors but you have to start insulting people by saying how do you know its not just some junk motor somebody threw together after i told you it came from a running bike and i saw the motor personally when it was here in omaha before he decided to sell it!
Then you find a loose sleeve in your block and i tell you it isnt a problem but once again you dont listen.
Then you find a 900 motor for $300.00 but you dont have the money for it,then you find what you think is a kaw sportbike which turns out to be a yamaha for $100 that dont run that you want us to find you parts for and to tell you how to fix it!
Now youre back to wanting to build a hotrod motor out of your origional motor and this time around price is no object,except you dont seem to realize the rest of the bike brakes/suspension..... is in the same shape as the motor! :woohoo: :woohoo:
