- Thank you received: 14
KZ1K'S ENGINE PROJECT
- dejavoodo41
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- keith1
- Thank you received: 2
due for it's 3500 mile oil change i waited a few extra miles and will do it 4000...need to get the tranny full flushed /serviced ? but am scared that the shop will do it and screw somthing up and it will be worse than just leaving it..it's full and does not look burned or brown..nice clean red......rumor has it the trans are fickle....
uses no oil...uses no coolant..runs cool now...shifter button popped off....use the sticks button
70 for a replacement handle/button....works till i hit a yard though...works great..
the thing is spotless--trouble free....and if i punch it it will stand up on the shocks and friggin smooth ass get booking......i am digging it...use it as my guard car at my night job and fits right in .they even let me just hang out in it most the shift ...makes for them a free plain clothes looking cop car really.......
thanks for the help on it also....best free car i ever had next to my datsun 310gx...free too....still only has 39000 miles....
and as far as getting it in the can...jimbo has gotten it in the can sooooo much they had to switch to bottles
AOD transmissions arent known for longevity.....there are a couple of schools of thought on the trans service.....if you dump the pan and change the filter, you dont get whats in the torque converter......if you do the suction route,you get all the fluid including the converter, but the filter isnt changed......i have heard a lot of people say the filters dont get that snotty with 30k tranny fluid changes.......in my marauder when i still had it,i had them do the suction thing and call it a day.....in a perfect world where money wasnt an object, i would have them do both, but that can get pricey.....the suction method will be 130-150 alone.....
- trianglelaguna
- Thank you received: 235
i think i jacked my mans thread enough...solly cholly....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- kz1k
- You Cant Fix Stupid!
i would like to start cleaning the outside of my motor. should i do this when the jugs and head are assembled or off? maybe someone has a thread on this allready. i dont have to get them showroom look, but want to get is a lot cleaner than i have it now. i have acess to a sandblaster if that makes a difference.
il going to google cleaning motorcycle motor, but would like some advice from you guys for sure.
1978 KZ1000A2
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Cam chain requires spliting the cases and all, unless you go with a master link style chain.
Cleaning engine with soda is said to provide the best results, and it washes away easily. Alot of other blast medias will cause damage if not very carefully completely removed from parts prior to assembly.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kz1k
1978 KZ1000A2
- kz1k
as far as the specs you mean measuring the sleeves and pistons?Jugs and pistons staying depends on wether ot not they meet spec. have you checked all the specs against the MANUAL?
i will be buying a master link cam chain.
ok soda. should i just do this when the whole engine is together? i have a sand blasting box, but im not sure the motor assembled will fit in there. if i do the motor while it is apart, are there any parts i need to stay clear of?
1978 KZ1000A2
- porchev914
- Thank you received: 19
FRANKEN Z!
- porchev914
Once they got done with my engine, it looked better than new, or at least what I imagined was better than new
FRANKEN Z!
- Thank you received: 2829
- kz1k
that looks really nice....only blast the bottom disassembled? what caution can i take to keep the media out of the bottom end?You shouldn't do any blasting on the bottom end while it's assembled. There is really no way to gaurantee you will keep any blast media out of the engine internals.
once its clean does it need further treatment to keep it that way?
1978 KZ1000A2
- porchev914
FRANKEN Z!
