KZ1K'S ENGINE PROJECT
- DoubleDub
- Visitor
- kz1k
- You Cant Fix Stupid!
we are just rambling about the "iron board" seats....i had a question that no one cared to answer. i am curious as to what kinda cash a redone stock kz1000 brings in compared to a aftermarket,(mono shock, diff forks, diff swing arm, diff seat, and bars, tires)kz1000?So, I'm confused. What was the question again?
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- DoubleDub
- Visitor
- DoubleDub
- Visitor
Aftermarket Kz's don't sell well. If you want to get money out of it, keep it as stock as possible. Then you'll only lose half.
- kz1k
so lets say the higher than average stock bike sells for 6k. it would take 12k to get it there?kz1k wrote:
1978 KZ1000A2
- kz1k
vm 26....ok. is there any reason i could not use these carbs by going to a 1075, and head work?kz1k wrote:
plummen.....
Yep, those are carbs. Probably VM26's.
1978 KZ1000A2
- Nebr_Rex
- Thank you received: 300
it could be worse...i could just shove the $ up my nose like i did in my teens.... :woohoo:
So you will be turning 20 on your next b-day.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- DoubleDub
- Visitor
Are you refering to the question about the bottom end? Pretty sure that was answered in the original thread when Larry said "From what I'm seeing the whole motor should be gone through". Yes, tear it all down, measure it all per the manual, verify that everything is in good working order, weld the crank if you plan on performance mods, and build it back up. I think everyone has agreed on that.
- DoubleDub
- Visitor
plummen.....
I still use my VM26 carbs on my 1075, but my head is not ported and I'm using stock cams. If you go with higher lift cams and porting you will probably want to look at some upgraded carbs, but they ain't cheap.
These are what seem to be the choice for new carbs (and the used carbs will cost roughly the same once rebuilt if you are looking at Mikuni 29's) www.dynoman.net/carb/keiCR.html
- DoubleDub
- Visitor
what are some options with aftermarket cams, and prices?
www.dynoman.net/engine/cams/webcams_kawa.html
www.kzzone.com/cams.html
I don't remember the lift size, but I think anything over .365 or .380 requires removing material from the head. The .430+ or so cams require switching to shim under buckets and are probably a bit big for a street-able 1075 engine from what I've read.
