KZ1K'S ENGINE PROJECT
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If you plan on blasting your bottom end, it should be entirely dissasembled to just raw cases. You can blast it assembled, but you need to build a block off plates for the piston ports from wood. Pull the studs, and just use some appropriate length bolts to hold it firmly inplace. The round holes/openings can be plugged with rubber expansion plugs, you can purchase from a local pool store.
I've seen glass, but didnt like the results. i believe theres alot more to it than jsut hitting it with air and some crushed media. There's a technique, and specific air pressure, and specific soda type, etc. for the best shiney results.
Do it, just DO IT.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- Kawickrice
- Thank you received: 18
Here is my 650 motor done with soda during a frame swap
Bag of soda from Harbour Freight and a cheap gun
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kz1k
1978 KZ1000A2
- Thank you received: 2098
...Once they got done with my engine, it looked better than new, or at least what I imagined was better than new
Thinking the company's name was mentioned in an earlier thread, but can't recall it.
Also vaguely remembering that it isn't paint, but that they wouldn't disclose the process.
Undeniably gorgeous!
Is she aging well?
There was another company (relatively expensive) that produced beautiful results by using a process that involved "rolling" the parts in a "polishing" media of some kind prior to reassembly.
- porchev914
- Thank you received: 19
FRANKEN Z!
- kz1k
1978 KZ1000A2
- TeK9iNe
when i do the jugs do i need to stay away from the sleeves?
YES absolutely. If a sleeve recieves so much as a whiff of any material like glass/sand/hard stuff at high pressure, then it will likely require replacement. The soda/walnet shell/soft stuff will not harm the sleeves if an occasional bit sprays in there. Do not spray any of it directly against a sleeve for any length of time purposely of course.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kz1k
im ganna use the glass bead i think...ill be careful to cover the inside of the sleeves.kz1k wrote:
1978 KZ1000A2
- porchev914
adam, is that a oil cooler i see to the left?
No sir Joe, that's the oil pan.
FRANKEN Z!
