KZ1K'S ENGINE PROJECT
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- PLUMMEN
- Thank you received: 104
check everything out before you start dumping tons of money into a non existing problem,theres plenty of very fast ol 900s and 1000s out there running the streets with the origional parts in their clutch baskets,for the most part its another one of those the racers do it so i need it also upgrades.
if the springs are broke/loose or deformed by all means replace them or just stick another basket in there off of ebay for $50
- kz1k
here we go again! $$$$$$ :laugh:that does not answer my question plummen.
1978 KZ1000A2
- testarossa
- Thank you received: 82
I am only suggesting that you check the springs and replace if broken or loose. Don't touch 'em if they look good.
Now just spread the two fingers of the shift lever over the shift drum on the right side of your picture, and the whole shift arm should slide straight out.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- PLUMMEN
i was talking about the clutch basket,you snuck yours in under the radar on me! :laugh:PLUMMEN wrote:
start by pulling the phillips head screw off the cover on outside of shift drum and the little spring on right side to remove the linkage and pull shift drum
- kz1k
i have 3 springs that are lose to the touch. ill give that shift lever a shot....brbI bet your keyboard is greasy.
1978 KZ1000A2
- trianglelaguna
- Thank you received: 235
watch out for getting doobie ashes in that finger cut ...it burns
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- kz1k
no doobie ash in cuts...lolgood job on the zip locks...i also put a small card in the bag with the label in sharpie...it seems the only one that ever rubs off the writing on the baggie is the one that i always need and cant remember it's location..index cards are great back up...if a yr goes by the memory will not be needed........blue painters tape and a sharpie is good for bigger parts wrap around a stud or bolt ect......
how do i remove this fking thing.
1978 KZ1000A2
