KZ1K'S ENGINE PROJECT
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- kawsakiman
- Thank you received: 6
- kz1k
ok the bolts on the inside......how many come out? it seems 2 in the center bottom may be difficult.ok, all the bolts are out....how do i crack the case?
1978 KZ1000A2
- larrycavan
- Visitor
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- PLUMMEN
- Thank you received: 104
so are you going to remove the oil pump,or are you going to use it to pull on? :laugh:
- kz1k
1978 KZ1000A2
- larrycavan
- Visitor
Did you make the cardboard pattern I told you to make?
- larrycavan
- Visitor
my manual isnt here yet.....i took out 25 bolts includint the 4 on the inside......the front right side of the motor is the only side that did not open. what am i missing?
Someone to weld the chunk back in you're going to break if you're not careful
Upside down...R/F would be where the 5 top case bolts are.
