Stu Pidasole's Build
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
Re: Stu Pidasole's Build
31 Jan 2011 05:32Please Log in or Create an account to join the conversation.
31 Jan 2011 05:41
have you sat on it yet the way you have it?
- Stu Pidasole
31 Jan 2011 05:44
531blackbanshee wrote:
yeah i sat on it. the shock was really tight. the spring was pressed almost all the way down. i moved the "rings" up 1" and its a little better.have you sat on it yet the way you have it?
- larrycavan
31 Jan 2011 05:49 - 31 Jan 2011 05:55
Stu Pidasole wrote:
If you do it the way I suggest, it's easier. You can build the bracket on your welding table. Then bolt it to the linkage. Swing it into position and have some adjustment to play with.
It's the same concept as the two brackets welded to the frame like in this photo but a lot easier to do and position.
Anyway, that's how I did it. Worked for me kid
Last edit: 31 Jan 2011 05:55 by larrycavan.
- Stu Pidasole
31 Jan 2011 05:53 - 31 Jan 2011 05:57
larrycavan wrote:
the way it sits right now is ok with me, but if you see something wrong please explain. remember im a lil slow...
the cross tube is tacked right now. i can move it some. or i can take the 2 mounts off. im just not sure what you meant with the origional comment. :SStu Pidasole wrote:
Last edit: 31 Jan 2011 05:57 by Stu Pidasole.
- Stu Pidasole
31 Jan 2011 05:58
larrycavan wrote:
thanks for the image. i can still do that with what i have. just not sure which way to move it, if any.Stu Pidasole wrote:
Anyway, that's how I did it. Worked for me kid![]()
- larrycavan
31 Jan 2011 06:01
Stu Pidasole wrote:
Based on the first pic I commented on, it didn't show the bottom bracket was made yet. If this photo is your bike, then you've done it so you can disregard the drawing.
When I positioned the shock, I wanted the shock to be sitting as perfectly vertical as I could get it. At the same time I wanted the dog leg to be positioned so the bottom of it was parallel with the floor.
In order to do that, I made the top mount first. Then the bottom mount as in the sketch. Result...shock centered in swingarm hole and sitting vertical with the linkage not cocked
larrycavan wrote:the cross tube is tacked right now. i can move it some. or i can take the 2 mounts off. im just not sure what you meant with the origional comment. :SStu Pidasole wrote:
Anyway, that's how I did it. Worked for me kidthe way it sits right now is ok with me, but if you see something wrong please explain. remember im a lil slow...
- Stu Pidasole
31 Jan 2011 06:03
yeah thats a photo of my bike. guess im good to go then. thanks larry.
- larrycavan
31 Jan 2011 06:07
Stu Pidasole wrote:
Weld the inside of those tabs too. And, it would't hurt to tie them together with a plate.
What's the top mount look like?
- Stu Pidasole
31 Jan 2011 06:10 - 31 Jan 2011 06:12
larrycavan wrote:
heres a side pic.... the top mount is not finished yet.Stu Pidasole wrote:yeah thats a photo of my bike. guess im good to go then. thanks larry.
Last edit: 31 Jan 2011 06:12 by Stu Pidasole.
- jus1975
- www.tripleaperformance.com
31 Jan 2011 08:49
what would be the difference if the shock was tilted a few degrees forward instead of vertical
- andy9802gt
- If it tastes that good, eat it yourself.
31 Jan 2011 09:22 - 31 Jan 2011 09:23
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Last edit: 31 Jan 2011 09:23 by andy9802gt.
