Stu Pidasole's Build
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
Re: Stu Pidasole's Build
28 Jan 2011 13:39
#426550
No it's okay test ever step on a piece of slag with a brand new pair boots and not realize until it was too late? Lol
  • trianglelaguna
  • trianglelaguna's Avatar
28 Jan 2011 13:41
#426551
the worse..i had slip on redwings when hanging iron...the slag from a cut got in and peeled the top thin skin off my foot before i could get my boot off...all of this happened about a hundred feet up....or the time i stepped on a freshly welded bridging for support to brace myself for the next weld ( while thinking about a scumbag girlfriend) and it popped free,,, i fell into the floor and was hanging on my underarms...on fresh welds...
I hate that woman......:blink:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
28 Jan 2011 13:54
#426552
testarossa wrote:
Leon, you should try one of these some time: www.iscar.com/Ecat/familyHDR.asp/fnum/23...TYP/M/type/1/lang/EN
I had a 4" diameter one running 4000 rpm at 100 inches/minute cutting aluminum on one of our open bed mills one time. It would throw chips into the next county. I set up a chip screen that was made from two screen doors hinged together to try and stop the chips. If left running too long the fiberglass screen material would start burning.
i have ran a face mill like that before(except it had four cutters),here at work back when i was the fabricator/machinist/engine builder/mechanic dude.
i would like to have one i just haven't been able to justify the price yet.
one day tho :silly: .
i have slag scars on my arms and legs where hot slag went into my boots/clothes mid weld.i danced around but finished the welds,which is why i scarred so bad.
  • testarossa
  • testarossa's Avatar
28 Jan 2011 14:00
#426553
That 4" cutter has 4 inserts also. They are damned expensive. The inserts are about $26 a piece, and I think the cutter is about $800 IIRC. It would put a hell of a load on your mill. You probably couldn't get away with the feed/speed that I was using on that bed mill. It was a Hurco BMC40, 15h.p. and that thing weighs 18,500 pounds. Doesn't exactly fit in a garage shop.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • 531blackbanshee
  • Vendor
  • Vendor
28 Jan 2011 18:02
#426602
testa,definately couldn't equal the feed/speed.
i have a couple home made fly cutters that can whack some material off.but it is just a small mill.i am just happy to be getting some work done with it.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
28 Jan 2011 19:06
#426619
No I can't say I've ever done that. But, I can say that I hit myself in the shin with an 8lb sledge hammer once. That'll make you wonder if you're gonna shit or puke. Still have the dent in my shin bone. :pinch:
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • porchev914
  • porchev914's Avatar
28 Jan 2011 19:36
#426626
Hey Pidasole, did you ever get a laser?
FRANKEN Z!
  • Stu Pidasole
28 Jan 2011 21:07 - 28 Jan 2011 22:05
#426635
yes a laser don't work half as good as a straight edge. i got my chain today, and a straight edge/ruler told me the "laser" was a waste of coin.:laugh:
Last edit: 28 Jan 2011 22:05 by Stu Pidasole.
  • porchev914
29 Jan 2011 00:11
#426663
You may find that there are things you can do with a laser that you can't do with a straight edge..... and a tool is only as good as the operator :P
FRANKEN Z!
  • stonemaster
  • stonemaster's Avatar
29 Jan 2011 04:53
#426693
straight edge, squares, levels are sufficient, use rigid measuring devices whenever possible, and if u do use a tape measure USE THE EXACT SAME ONE THROUGH THE ENTIRE PROCESS, Double check all measuring devices against each other, there are inaccuracies, I have see many time two tape measure side by side comparisons that were off.
Lasers are really cool if u want ur cat to chase the little dot on the wall, THEY LOVE DAT STUFF :blink:
  • larrycavan
  • larrycavan's Avatar
29 Jan 2011 05:10
#426700
Joe,
You're off in an entirely different direction than I went. That's fine. Run with it. No two bikes should be alike IMO any.
I set certain design criteria before I even began. At the top of the list was a desire to have the finished product look like it came from the factory.
In other words, if Kawasaki had the suspension available back in 79 and was going to make a limited production run of bikes that didn't distract completely from the original styling, what would it have looked like....
Classic but modern at the same time ;)
I'll be checking in to see what you come up with...
Larry C
  • Stu Pidasole
29 Jan 2011 07:03
#426729
yep, i used my neighbors laser, but felt more comfortable with the good ol level/square/tape. got a lot done last night. ill post progress later. gatta get back out there.
