Stu Pidasole's Build
- porchev914
Re: Stu Pidasole's Build
29 Jan 2011 08:34
stonemaster wrote:
Means and methods my friend. One is not necissarily better than the other, as long as the finished products quality is not comprimised
straight edge, squares, levels are sufficient, use rigid measuring devices whenever possible, and if u do use a tape measure USE THE EXACT SAME ONE THROUGH THE ENTIRE PROCESS, Double check all measuring devices against each other, there are inaccuracies, I have see many time two tape measure side by side comparisons that were off.
Lasers are really cool if u want ur cat to chase the little dot on the wall, THEY LOVE DAT STUFF :blink:
FRANKEN Z!
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
29 Jan 2011 09:41
1 more weld in my frames back together. Let me get back to work.
- stonemaster
29 Jan 2011 09:42
porchev914 wrote:
whateverstonemaster wrote:straight edge, squares, levels are sufficient, use rigid measuring devices whenever possible, and if u do use a tape measure USE THE EXACT SAME ONE THROUGH THE ENTIRE PROCESS, Double check all measuring devices against each other, there are inaccuracies, I have see many time two tape measure side by side comparisons that were off.
- Stu Pidasole
29 Jan 2011 10:19
The frame is done I think it's time for some lunch. Then I need to put in the new rear lower:woohoo: motor and shock mount.
- stonemaster
29 Jan 2011 10:59
come on joe ya slacker!
stoppin to eat lunch :S yer killin me!
- Stu Pidasole
29 Jan 2011 13:09
ok Leon, and Adam...:lol:
the frames back in one piece....I also put a new lower/rear motor/shock tube in. dont mind the tube in the front. it was just there to keep everything the same. havnt removed it yet.
- Stu Pidasole
- Marneman
29 Jan 2011 14:33
We're gonna hook you up to an I.V. for dinner so that hunger thing won't interupt the build :laugh:
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
- Stu Pidasole
29 Jan 2011 16:31
oh yeah!lookin good.did you check out the frame bracing thread i bumped back up?
- Stu Pidasole
29 Jan 2011 16:38
531blackbanshee wrote:
thanks Leon. i saw the thread you speak of, but i thought there was a email that was suposed to be sent with more info?:blink: or is it all in the thread?..Joeoh yeah!lookin good.did you check out the frame bracing thread i bumped back up?
