Stu Pidasole's Build
  • z1kzonly
  • z1kzonly's Avatar
Re: Stu Pidasole's Build
31 Jan 2011 10:31
#427411
All this new stuff is fine, all you guys know your stuff!
I am sure these updates will make these old KZ's safer and more comfortable to ride.
I was wondering? Where do you put all the electrics and battery box?
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
31 Jan 2011 11:07
#427425
im obviously far from wiring my personal build, but under the seat i supose.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
31 Jan 2011 13:03
#427452
jus1975 wrote:
what would be the difference if the shock was tilted a few degrees forward instead of vertical
that's what I was wondering. seems awfully vertical.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • Stu Pidasole
31 Jan 2011 13:20
#427454
the words of Larry........"Based on the first pic I commented on, it didn't show the bottom bracket was made yet. If this photo is your bike, then you've done it so you can disregard the drawing.
When I positioned the shock, I wanted the shock to be sitting as perfectly vertical as I could get it. At the same time I wanted the dog leg to be positioned so the bottom of it was parallel with the floor.
In order to do that, I made the top mount first. Then the bottom mount as in the sketch. Result...shock centered in swingarm hole and sitting vertical with the linkage not cocked."
  • larrycavan
  • larrycavan's Avatar
31 Jan 2011 15:48
#427484
:woohoo: Good Guess Joe!
Don't forget your side covers need to mount too. Scope that out now. Looks like the top shock mount tube might cause a problem with that. You might need to modify a bit :)
  • Stu Pidasole
31 Jan 2011 15:56
#427486
i took that into consideration. it squeeks by.:) thanks Larry.
  • larrycavan
31 Jan 2011 15:59
#427489
Stu Pidasole wrote:
larrycavan wrote:
Stu Pidasole wrote:
yeah thats a photo of my bike. guess im good to go then. thanks larry.
Weld the inside of those tabs too. And, it would't hurt to tie them together with a plate.
What's the top mount look like?
heres a side pic.... the top mount is not finished yet.
The thing that concerns me, based on this picture is rear tire to frame clearance.
The rear travel is 5.5" as I recall. How the bike sits unladen is one thing. How it sits fully assembled is another matter. You're going to loose travel and it looks tight already.
Here's mine with only empty cases, save the output shaft.
Looks like a lot of clearance in the rear but I had a problem with my license plate and tire contacting at first.
  • larrycavan
31 Jan 2011 16:04 - 31 Jan 2011 16:09
#427491
Current plate mount
Whatever.... scope out those couple of things I pointed out Joe and see what / if you need to address them.... Carry On and DO NOT PUT BS34's on that bike when you're done or I'll drive to Florida and set it on fire :woohoo:
Last edit: 31 Jan 2011 16:09 by larrycavan.
  • Stu Pidasole
31 Jan 2011 16:23
#427498
larrycavan wrote:
Current plate mount
Larry,remember i am short, so im trying to keep it as low as i can. but nothings written in stone. i can still play with ride height if needed. so if i have 6" from tire to frame i should be ok?
also, not familar with the bs34....why do you say dont put them on?:S
  • Stu Pidasole
31 Jan 2011 16:33
#427500
also Larry, when i unbolt my bottom mount that goes to the motor mount tube, and move the dog leg further away i get more clearence. i would just have to make the 2 mount tabs longer. lemme know...Joe
  • larrycavan
01 Feb 2011 13:11
#427673
Stu Pidasole wrote:
larrycavan wrote:
Current plate mount
I'm just joking about the carbs Joe ;) Not Really... Maybe....Probably Not..... :woohoo:
  • hocbj23
  • hocbj23's Avatar
01 Feb 2011 13:30
#427675
larrycavan wrote:
Current plate mount
Joe: I have a set of BS34s I will give u if u put them on the bike.I want to see LC get arrested in Florida for arson.Lol.bj
