Stu Pidasole's Build
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
Re: Stu Pidasole's Build
30 Jan 2011 11:05
#427112
Thanks larry.
Today im getting the mono mounts in.......not sure what im ganna do with the verticle supports yet. i hope the shock drops through the bottom...:laugh: ganna have to try it.
  • Stu Pidasole
30 Jan 2011 11:06
#427113
  • Stu Pidasole
30 Jan 2011 11:07
#427114
......mocked up.........
  • porchev914
  • porchev914's Avatar
30 Jan 2011 14:36
#427162
Much better than the bed frame shock mount Joe ;) you may wish to add some little gussets from the cross brace to the frame. Nothing big, just to help strengthen against that tube from wanting to rotate up with the shock under compression
FRANKEN Z!
  • Stu Pidasole
30 Jan 2011 15:26
#427172
for sure adam. I got the bottom brace done too. My neighbor needed his trailer welded....pics of mono finished to come........
  • Stu Pidasole
30 Jan 2011 16:22
#427186
okay....
  • Stu Pidasole
30 Jan 2011 16:23
#427187
  • Stu Pidasole
30 Jan 2011 16:24
#427188
  • Stu Pidasole
30 Jan 2011 16:25
#427190
  • Stu Pidasole
30 Jan 2011 16:28
#427194
my friend had some bubble gum welds on his trailer... i would have got more done today but he came over with about 5-6 welds that needed to be grindes down and re-welded....needless to say....between my build, his trailer, and kids....i was busy. did i eat today? wheres my iv? :woohoo:
  • Marneman
  • Marneman's Avatar
30 Jan 2011 16:33
#427195
Those are looking good Joe B)
Go eat man!
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
  • larrycavan
  • larrycavan's Avatar
31 Jan 2011 05:29 - 31 Jan 2011 05:44
#427310
Stu Pidasole wrote:
Thanks larry.
Kind of looks to me like you bound yourself a bit tight for the shock linkage :unsure:
For the bottom linkage connector:
Use a curved piece formed to the cross tube. Weld your two tabs for the bolt to that curved piece. Bolt the assembly to the linkage. That will allow you to swivel it into correct position on the cross tube. Tack it, then look things over.
Here's a quick dirty sketch that should get the idea across.
Last edit: 31 Jan 2011 05:44 by larrycavan.
