Stu Pidasole's Build
  • larrycavan
  • larrycavan's Avatar
Re: Stu Pidasole's Build
01 Feb 2011 14:44 - 01 Feb 2011 15:09
#427684
I see the fool bus stopped by and let off a passenger :P
Last edit: 01 Feb 2011 15:09 by larrycavan.
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
02 Feb 2011 15:55
#427935
ok, since i am looking to end up with a semi street fighter look on the bike i was wanting to kick up my rear fender. this also gave me more clearance for shock travel when it comes to the frame and rear tire gap.
  • Stu Pidasole
02 Feb 2011 15:56
#427937
after i kicked it up. its not welded yet, so i have room to play if i change my mind some.
  • Stu Pidasole
02 Feb 2011 15:57
#427938
  • porchev914
  • porchev914's Avatar
02 Feb 2011 16:50
#427952
Hey Joe, make sure you put the seat on too while you're doing that. Where you cut the subframe will make a difference how the tail piece and seat fit together. I'd hate to see you have problems because you made a mod without all of the pieces of the puzzle ;)
FRANKEN Z!
  • Stu Pidasole
02 Feb 2011 16:50 - 02 Feb 2011 16:53
#427953
its barely moved. i did put the origional seat on with the tail and its fine. but i will not be using the factory seat. im not sure im ganna keep the frame tail tubing, i might hack half of it off.:woohoo: not sure yet.
Last edit: 02 Feb 2011 16:53 by Stu Pidasole.
  • porchev914
02 Feb 2011 16:54 - 02 Feb 2011 16:55
#427955
Even if you're not using a factory seat, the seat pan is going to fit the chassis the same as a stocker. You can mock up with the seat you have have, then swap the seat out when you get a replacement.
FRANKEN Z!
Last edit: 02 Feb 2011 16:55 by porchev914.
  • Stu Pidasole
02 Feb 2011 17:01 - 02 Feb 2011 17:03
#427958
factory seat. well by the looks of things i could even go higher, but for now....waiting on triples, ill leave it unwelded.
Last edit: 02 Feb 2011 17:03 by Stu Pidasole.
  • camaroguy
  • camaroguy's Avatar
03 Feb 2011 03:14
#428076
Dont know but, in pictures I think your going to end up to low in back?may want to install side covers to look at how they sit on there as well .if height is an issue can you have the seat cut down?like the direction of bike just dont want you to get it all together painted and all to find tire clearance becoming an issue.
  • larrycavan
03 Feb 2011 04:32 - 03 Feb 2011 06:18
#428083
A man hears what he wants to hear and disregards the rest...
When you get the front end bolted on, do a mock up to see how things are coming together.
Get the cases back in the frame with the block and head on them. Mount the carbs. Put the header on. Put the chain and sprockets on. Sit on the bike....
I'm curious to see if there's going to be any swingarm to engine case clearance issues.
Get the bike as "together" as you can and look for problems.
Last edit: 03 Feb 2011 06:18 by larrycavan.
  • Stu Pidasole
03 Feb 2011 07:42 - 03 Feb 2011 07:43
#428125
heights not an issue as it sits. nothings written in stone. waiting on triples so i can slap the front on. i def will not be using this seat though. damn ugly. also, the side covers have been on with no issues.
Last edit: 03 Feb 2011 07:43 by Stu Pidasole.
  • Stu Pidasole
03 Feb 2011 07:45
#428126
Larry, i took a grinder to the swingarm where you told me for case clearence. cases have been in allredy, just took em out to put in the new rear motor mount/arm tube. i will get the front on, then cases, jugs, head, and headers before i go any further as a mock up. thanks.
