Stu Pidasole's Build
- larrycavan
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
Re: Stu Pidasole's Build
08 Feb 2011 13:15
larrycavan wrote:
wish i had a thanks button.......thanks larry. you da man.Ok. Just looked like a potential issue
- meds
09 Feb 2011 14:06
Stu Pidasole wrote:
Wow,thats gonna cut into my dorito's budget! :blink:
- meds
09 Feb 2011 14:17
How hard would it be to to use this swingarm on my 73 900?
I found a bunch of black threaded pipe from when they replaced the furnace in my apartment,Can I use this for bracing or do I need to use the shiny threaded pipe like they sell at Lowes?
- Frankn9
09 Feb 2011 14:24
their are so many people on here with a wierd sense of humor, but I really really hope this is a joke!
- z1kzonly
09 Feb 2011 14:31
meds wrote:
I did on my first dragbike!
My backbone fuel cell was made from schedule 40
black pipe. And I used a 3/8" ballcock valve for the gas shut off. I wish I had a picture.
Yes I would use it for bracing, no big deal.
- Stu Pidasole
09 Feb 2011 14:55 - 09 Feb 2011 14:56
MEDS!!!! on the top right side of your computer screen there is a lil green blinking envelope. its your pm box. click it. its right under your user name. Joe
Last edit: 09 Feb 2011 14:56 by Stu Pidasole.
- Stu Pidasole
10 Feb 2011 12:08 - 10 Feb 2011 12:09
Last edit: 10 Feb 2011 12:09 by Stu Pidasole.
- Stu Pidasole
- Stu Pidasole
10 Feb 2011 12:14 - 10 Feb 2011 12:15
Last edit: 10 Feb 2011 12:15 by Stu Pidasole.
10 Feb 2011 12:22
Stu Pidasole wrote:
Chain looks to be running pretty close to the swingarm. Have you checked to see if it touches anywhere through the full up and down swing of the arm? If so you may consider larger sprockets. Ed
- Stu Pidasole
10 Feb 2011 12:24 - 10 Feb 2011 12:54
650ed wrote:
there is a 3/4" gap between the swingarm and the chain. also the bike has no weight in it. there will be a chain guard installed before its all said and done. Larry C. has the same sprockets i do. I dont hear him complaining. Go Larry! The nice thing is he has done most of the guess work. Once i got past the frame mods, it should run a lil smoother.
Last edit: 10 Feb 2011 12:54 by Stu Pidasole.
