Stu Pidasole's Build
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
Re: Stu Pidasole's Build
10 Feb 2011 22:32 - 10 Feb 2011 22:35
#429906
did some adjusting. looks better allready.B) ill get a pic up.....
Last edit: 10 Feb 2011 22:35 by Stu Pidasole.
  • Stu Pidasole
10 Feb 2011 22:36
#429908
  • larrycavan
  • larrycavan's Avatar
  • Visitor
12 Feb 2011 15:12
#430256
Try to put your sprocket cover on. See where you stand with that. Probably going to need some attention there too Joe.
Gut the cover first.
  • Stu Pidasole
13 Feb 2011 12:01
#430426
i hear ya larry. still waiting on the front end parts before i do anything else. i wanna get the front and rear perfect with chain travel, then ill try the front sprocket cover. i know, not much progress, when the triples show ill be moving along.....i hope...lol
15 Feb 2011 01:31
#430778
  • Stu Pidasole
17 Feb 2011 07:34
#431231
i just realized my old races are still in my neck. not sure how to remove them.
  • Stu Pidasole
17 Feb 2011 07:39
#431232
well that took all about 5 minutes. :) the top 1 was a lil easier. the bottom one was a lil harder. i had to weld a piece of solid round bar to it and knock the round bar with a hammer. easy as pie. new ones are pressed in and i should have Leones triples this afternoon allowing me to install the front end.:)
  • Stu Pidasole
17 Feb 2011 07:39 - 17 Feb 2011 07:50
#431233
.....B) out with the old.
Last edit: 17 Feb 2011 07:50 by Stu Pidasole.
  • Stu Pidasole
17 Feb 2011 07:40
#431234
.....B) i removed all the powder coat top and bottom where the races rest.
  • DoubleDub
  • DoubleDub's Avatar
  • Visitor
17 Feb 2011 08:48
#431238
I think I had to cut one of the out with a cutoff wheel on a dremel. I don't think I had to cut all the way through. I'll see if I can find my posts on this.
Here it is: kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=295087
  • Stu Pidasole
17 Feb 2011 08:53 - 17 Feb 2011 08:54
#431240
yeah i read that. unfortunatly i dont have one. i lost it during a move. the rod/weld worked like a champ. i would choose that over using a cutting wheel near the neck any day. thanks for stoppin in DD.:)
Last edit: 17 Feb 2011 08:54 by Stu Pidasole.
  • DoubleDub
  • Visitor
17 Feb 2011 09:35
#431248
It actually wasn't bad, I don't believe I had to cut all the way through them before they released the tension and fell out.
