Stu Pidasole's Build
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
Last edit: 19 Feb 2011 11:21 by Stu Pidasole.
- Stu Pidasole
- Stu Pidasole
- Stu Pidasole
- Stu Pidasole
- Stu Pidasole
- PLUMMEN
Re: Stu Pidasole's Build
20 Feb 2011 08:15
id weld all the way up and down both sides of that gusset
so whats gonna hold your ass up now?
- Stu Pidasole
20 Feb 2011 08:23 - 20 Feb 2011 08:25
PLUMMEN wrote:
i will Plummen. once i take the bike apart to paint i can get the inside. as for my ass, there will be a brace that goes up to the seat frame. just a cleaner look than the stock tubing route, keeeping the swingarm "open".id weld all the way up and down both sides of that gusset
Last edit: 20 Feb 2011 08:25 by Stu Pidasole.
- PLUMMEN
20 Feb 2011 08:25
battery box?
- Stu Pidasole
20 Feb 2011 08:27 - 20 Feb 2011 08:30
PLUMMEN wrote:
and remember, the frame is wider below the seat....more room for electronics and batt than stock.
yes. much smaller than stock, same cranking amps. side covers will hide it all. i am not sure if im ganna use stock covers, or make my own.battery box?
Last edit: 20 Feb 2011 08:30 by Stu Pidasole.
- porchev914
20 Feb 2011 09:09
It's not that much wider than stock Joe! Don't forget those gussets on your upper shock mount. When's trash day again? :laugh:
FRANKEN Z!
- Stu Pidasole
20 Feb 2011 09:21 - 20 Feb 2011 09:34
porchev914 wrote:
the gussets for the shock mount will be welded before the bikes done....no rush. i have a zillion other things to check off the list. i did a search on what it would cost to ship the bike to california. with your near future plane purchase you cant afford it.:laugh: unless itll fit in the plane.:blink:
i said it is wider, not a lot wider. 10" is my spread between the frame where the swingarm is. my $ is on stock is not that wide. allowing more room the last time i checked.It's not that much wider than stock Joe! Don't forget those gussets on your upper shock mount. When's trash day again? :laugh:
Last edit: 20 Feb 2011 09:34 by Stu Pidasole.
