Stu Pidasole's Build
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
Re: Stu Pidasole's Build
17 Feb 2011 16:20
#431333
what front end is that?
1979 kz 1000 06 katana 750
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
17 Feb 2011 16:21
#431334
lemo32 wrote:
Thats a damn good looking roller joe, keep on keepin on buddy! B)
thanks Lemo:) .
  • Stu Pidasole
17 Feb 2011 16:41
#431339
2000 zx7r ninja
  • Stu Pidasole
17 Feb 2011 17:01
#431347
i almost forgot. Larry, much thanks also.
  • larrycavan
  • larrycavan's Avatar
17 Feb 2011 17:02 - 17 Feb 2011 17:05
#431349
Getting closer :)
Steering stop.
Best crank the ride height adjusters down to max if you're not going to run the forks flush with the top tree Joe.
Get a 1000 LTD 78 - 80 model, head light mount bracket. It will bolt right up to the top tree using those 2 6mm bolt holes. Clean, simple.... ;)
Last edit: 17 Feb 2011 17:05 by larrycavan.
  • Stu Pidasole
17 Feb 2011 17:05
#431350
larrycavan wrote:
Getting closer :)
Steering stop.
thanks Larry. i just pmed you about the stops. i was ganna grind the lower triple stops a lil to get more radius. lemme know. also, i am missing one of the steering nuts with the notches in it. (not sure of the name). anyway i believe i have the upper nut, and need to find a lower one. (anyone got a extra out there)? so once i get the nut, the triples will sit a lil closer to flush. but anyway, lemme know about the stops, thanks.
  • larrycavan
17 Feb 2011 17:18
#431355
Stu Pidasole wrote:
larrycavan wrote:
Getting closer :)
Steering stop.
I gave up some turning radius. At first it seemed like a lot but after putting miles on the bike, I don't even notice it anymore. Only affects you when turning the bike around in the garage...
In situations like that, just lean it over to the left, rip the revs up to 7k and let the clutch fly.... she'll spin right around for ya.... :woohoo: .... KIDDING... don't really do that :laugh:
  • Stu Pidasole
17 Feb 2011 17:21
#431357
larrycavan wrote:
Stu Pidasole wrote:
larrycavan wrote:
Getting closer :)
Steering stop.
:laugh: why did i picture you doing that?...:laugh:
  • porchev914
  • porchev914's Avatar
17 Feb 2011 17:50
#431371
Your welcome Joe. I've turned dirt bikes around like that, but I've never tried it on a street bike :blink:
FRANKEN Z!
  • larrycavan
17 Feb 2011 20:15
#431416
I think this thread as more PM's than posts :laugh:
Here's the schematic on the stem.
  • larrycavan
17 Feb 2011 20:16
#431417
Oh hell, that didn't work too good.
Here's the link
www.bikebandit.com/houseofmotorcycles/19...-us/o/m3934#sch83737
  • testarossa
  • testarossa's Avatar
18 Feb 2011 04:35
#431460
Joe, the roller looks good. You have come a long way from where you started. Here's how I solved the steering stop issue on my bike:
It's just a piece of 1/8" plate welded to the bottom of the factory stop. I actually set mine to keep clip-ons off the tank if I decided to go that route. If you plan on running bars you can get away with more turning radius. You just need to keep the fork tubes off the tank. As Larry says, I lost some garage steering only. It makes no difference on the road. Your steering inputs are very small when the bike is rolling.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
