Stu Pidasole's Build
Re: Stu Pidasole's Build
10 Feb 2011 12:58
My question was based on the fact that under compression the bottom length of chain will move closer to the swingarm and under rebound the top length of chain will move closer to the swingarm. This is fairly easy to check. However, if Larry is using the exact same setup including swingarm and sprockets and there is no contact between chain and swingarm you should be ok. If not, you'll find out when you hit the first bump. :laugh:
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
10 Feb 2011 13:16 - 10 Feb 2011 13:19
650ed wrote:
all that also depends on shock travel setting, and or sag. i forgot how many miles Larry has on his bike. in any case the rear sprocket i baught was $20. once it wears i will put a steel/titanium one on the bike. by then ill know for a fact if i need to bump up rear sprocket diameter.My question was based on the fact that under compression the bottom length of chain will move closer to the swingarm and under rebound the top length of chain will move closer to the swingarm. This is fairly easy to check. However, if Larry is using the exact same setup including swingarm and sprockets and there is no contact between chain and swingarm you should be ok. If not, you'll find out when you hit the first bump. :laugh:
Last edit: 10 Feb 2011 13:19 by Stu Pidasole.
- Kidkawie
- I bleed premix
10 Feb 2011 13:26
Stu Pidasole wrote:
Sag has nothing to do with shock travel. Travel is built into the shock and by the stopper on the base of the shaft. But you have flat roads so no worries.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Stu Pidasole
10 Feb 2011 13:48
so if my chain rides against the chain guard on the top of the swing arm it wont work?
- porchev914
10 Feb 2011 14:04
Kidkawie wrote:
What kidkawie means is that total shock travel is set by the manufacturer and is not readily changed, if at all. That said, your sag setting will take up some of the available travel. Remember, travel is measured at the wheel, not at the shock. To check your chain to swingarm clearance, remove the shock spring then reassemble the rear suspension. This will allow you to move the swingarm throughout its range and see what hits where
Stu Pidasole wrote:all that also depends on shock travel setting, and or sag.
FRANKEN Z!
- Stu Pidasole
- larrycavan
10 Feb 2011 14:15 - 10 Feb 2011 14:17
Stu Pidasole wrote:
There's a plastic chain guide that goes on the arm. There's no issue with the chain being to close to anything that I see in the pictures
If the guide didn't come on the arm, buy one. You want it on there for sure.
650ed wrote:there is a 3/4" gap between the swingarm and the chain. also the bike has no weight in it. there will be a chain guard installed before its all said and done. Larry C. has the same sprockets i do. I dont hear him complaining. Go Larry! The nice thing is he has done most of the guess work. Once i got past the frame mods, it should run a lil smoother.
Last edit: 10 Feb 2011 14:17 by larrycavan.
- Stu Pidasole
10 Feb 2011 14:17 - 10 Feb 2011 14:17
larrycavan wrote:
Thanks Larry!
Stu Pidasole wrote:650ed wrote:there is a 3/4" gap between the swingarm and the chain. also the bike has no weight in it. there will be a chain guard installed before its all said and done. Larry C. has the same sprockets i do. I dont hear him complaining. Go Larry! The nice thing is he has done most of the guess work. Once i got past the frame mods, it should run a lil smoother.
Last edit: 10 Feb 2011 14:17 by Stu Pidasole.
- larrycavan
- Stu Pidasole
10 Feb 2011 14:27
larrycavan wrote:
yeah i need to buy one. the one that came off it was all fked up.
10 Feb 2011 15:49
Stu Pidasole wrote:
Be sure to order a chain GUIDE rather than GUARD. When you said you were going to install a chain guard I didn't see how that was related to the chain touching the frame. Ed
Chain GUARD:
Chain GUARD:
- Stu Pidasole
10 Feb 2011 16:58 - 10 Feb 2011 17:44
Im just a lost cause ain't I ed? Lol. I said it wrong....if you though I thought a chain guard is what I needed to keep my chain off my swing arm....well...:laugh:
Last edit: 10 Feb 2011 17:44 by Stu Pidasole.
