Stu Pidasole's Build
- kz1k
- You Cant Fix Stupid!
Re: Joe's '78 kz1000 build
09 Jan 2011 12:45
PLUMMEN wrote:
my rear wheel is centered....let me as you a question.....where do i measure the front sprocket, the center, or outside?now get that rear wheel centered and figure out your offset
1978 KZ1000A2
- trianglelaguna
09 Jan 2011 12:46
put rags in the jugs around the rods...looking good...going for a ride ..i will check in lates....
flounder is cool cause the eyes both looking at the human
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- PLUMMEN
09 Jan 2011 12:54
do you have the output shaft installed?
install sprocket on output shaft and run straightedge from outside of rear sprocket to countershaft sprocket and measure differance.
- kz1k
09 Jan 2011 13:02
heres a few measurements with stock sprocket. straight edge outside is centered on hub bolts in rear....:huh:
1978 KZ1000A2
- PLUMMEN
09 Jan 2011 13:24
which part of the level is laying on rear hub?
if the straightedge is on rear hub without sprocket then you need to measure engine side of countershaft sprocket from same edge to figure your offset
- kz1k
09 Jan 2011 13:28 - 09 Jan 2011 13:29
PLUMMEN wrote:
heres the scoop.....i have the straight edge outside on the center of the rear sprocket hub bolts, (where the center of the rear sprocket will be.)
and if i take a measurement from the center of the stock front sprocket to the straight edge outside, (the line of the center of the rear sprocket,) it measures 7/8" center to center.
photos comming.....
photos comming.....
1978 KZ1000A2
Last edit: 09 Jan 2011 13:29 by kz1k.
- kz1k
09 Jan 2011 13:35
here.....the inside of the straight edge is flush againt both sides of the side of the tire, and the outside is about where the center of the rear sprocket will go.....
1978 KZ1000A2
- kz1k
09 Jan 2011 13:37
now this may be a lil off, but its the basic idea of how far out i am for the offset..... center of stock sprocket to center line, (outside straight edge).
1978 KZ1000A2
- PLUMMEN
09 Jan 2011 13:46 - 09 Jan 2011 13:50
do you have a rear sprocket you can mount on the wheel to get more exact measurement?
that tire being a 1/16" off top/bottem of that rim can really add up over 25"-30" to that counter sprocket
Last edit: 09 Jan 2011 13:50 by PLUMMEN.
- kz1k
09 Jan 2011 13:53
PLUMMEN wrote:
yeah i got my stock kz one, but i dont know if the sprocket bolt holes line up. and to pull the wheel off and put it back on is a biatch. i think i will order my zx7r rear sprocket. what should i look for? a 530 41 tooth zx7r rear sprocket? then i can know for sure what i need for my front.do you have a rear sprocket you can mount on the wheel to get more exact measurement?
1978 KZ1000A2
- kz1k
09 Jan 2011 13:58
will this work? i just emailed seller to see if itll fot my year.....
cgi.ebay.com/ebaymotors/BRAND-NEW-PBI-RE...&hash=item255bfde867
or i could go with a 45 tooth.
1978 KZ1000A2
- kz1k
09 Jan 2011 14:03
1978 KZ1000A2
