Stu Pidasole's Build
- kz1k
- You Cant Fix Stupid!
Re: Joe's '78 kz1000 build
10 Jan 2011 07:11
i called pmf. the gentleman told me to put a straight edge on both sides of my rear tire. then measure the distance between. came out to 7-1/8" then he had me measure from the side of the tire to the inside mount of the sprocket hub. it came out to 1". he told me unless i move my tire to the right, the chain will hit the frame. i explained that the frame has been spread to accomidate the wider swingarm.
with the 7-1/8" and 1" measurement he came up with 7/8" offset.
1978 KZ1000A2
- kz1k
10 Jan 2011 07:39 - 10 Jan 2011 07:45
well i took the front sprocket off. i tied a 1/4" rope to the end of the front sprocket housing. ran it back and wrapped around the center of the rear sprocket hub. i also used a straight edge to make sure the rope was straight. once again, not the most acurate, but i came up with a 5/8" diff. from center of sprocket teeth to rope. seems like i need to buy my rear sprocket and a chain to find out exactly....unless one of you has a secret?
1978 KZ1000A2
Last edit: 10 Jan 2011 07:45 by kz1k.
- kz1k
10 Jan 2011 07:40
1978 KZ1000A2
- kz1k
10 Jan 2011 07:41
1978 KZ1000A2
- kz1k
10 Jan 2011 07:42
1978 KZ1000A2
10 Jan 2011 08:10
you are campin out rubbin sticks together to make fire!
you need that rear sprocket for the zx wheel before you try to figure out what front offset you need.until you get the rear sprocket you are wasting time.
my opinion fwiw,
my opinion fwiw,
- kz1k
10 Jan 2011 08:14 - 10 Jan 2011 08:16
531blackbanshee wrote:
thanks leon, i really like this one. cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...:X:BOCOR:MOTORS:1123 good deal too. seller came down to 30 bucks. just not sure about the fit. the seller said if it dosnt work they will take it back....whatcys tink?you are campin out rubbin sticks together to make fire!
my opinion fwiw,
1978 KZ1000A2
Last edit: 10 Jan 2011 08:16 by kz1k.
10 Jan 2011 08:26
it will prollly work,you can try and send it back if it doesn't.
plus it looks like it may be a little offset one way or the other so that may help later to line up your sprockets.
- trianglelaguna
10 Jan 2011 09:13
geeez there must be an echo in here....
do what Larry says or he will get mad at us
....but i think you just build the bike and match the chain and offset to the zx sprocket....
but then i dont hack these shits apart so pay me no mind...:blink:
my opinion fwiw,
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- kz1k
10 Jan 2011 13:40 - 10 Jan 2011 13:40
here is the rear sprocket i went with. i spoke with PBI and looked at thier chart, and it says itll work for my year hub. its straight not offset.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...geName=STRK:MEWNX:IT
1978 KZ1000A2
Last edit: 10 Jan 2011 13:40 by kz1k.
- kz1k
10 Jan 2011 18:34
since im such a noobie, whats the 530 and 630 part of a chai meeen?
1978 KZ1000A2
- andy9802gt
- If it tastes that good, eat it yourself.
10 Jan 2011 18:42 - 10 Jan 2011 18:44
If I recall the first two numbers are link length and width in 1/8th's of an inch. So a 530 would be 5/8"Lx3/8"W, a 630 would be 3/4"Lx3/8"W, I think.....maybe...I don't know....
just trying to up my post count......
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Last edit: 10 Jan 2011 18:44 by andy9802gt.
