Stu Pidasole's Build
  • z1kzonly
  • z1kzonly's Avatar
Re: Joe's '78 kz1000 build
10 Jan 2011 19:04
#421352
That's simple enough 530, 630.
I'm doing a project with a new 530 countershaft.
I'm using a ZX10 rear wheel with 525? Factory rear sprocket.
What's the differance from 530 to 525?
Thanks
  • testarossa
  • testarossa's Avatar
10 Jan 2011 19:07 - 10 Jan 2011 20:50
#421353
Andy's got it. The first digit is length in 1/8s of an inch. Second two numbers is sprocket width in 1/8's also. 530 = 5/8" long x 3/8" wide. 630 = 6/8" or 3/4" long x 3/8" wide.
Now for the pop quiz what does 525 chain equal?
Edit, I'll answer my own question since z1kzonly asked. 525 is 5/8" by 5/16" wide. It's an oddball size. Better to convert to 530, much more common.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Last edit: 10 Jan 2011 20:50 by testarossa.
  • DoubleDub
  • DoubleDub's Avatar
10 Jan 2011 19:37
#421373
This link from Z1E has a great explanation with *pictures* :)
But seriously...it's a good link.
www.z1enterprises.com/reference/chain630to530.aspx
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
10 Jan 2011 20:44 - 11 Jan 2011 12:50
#421409
1978 KZ1000A2
Last edit: 11 Jan 2011 12:50 by kz1k.
  • larrycavan
  • larrycavan's Avatar
11 Jan 2011 05:01
#421454
When you get the chain and sprockets on there, run a narrow straight edge down the chain and let it extend back past the rear wheel.
Have the axle nut loose enough to allow the chain slack adjusters to move the wheel.
Get the chain running straight.
Place the straight edge on the chain & let it rest against the inside edge of the link plates.
Measure the gap from the straight edge to the tire, front & back. That will show you if your wheel and chain are running parallel.
  • kz1k
11 Jan 2011 13:03
#421514
cool larry. its ganna be a week or so before i get my rear sprocket, so i am nervouse about ordering my front offset sprocket until the rear one gets here. :(
1978 KZ1000A2
  • porchev914
  • porchev914's Avatar
11 Jan 2011 13:54
#421529
Do not order your front sprocket until you mount the rear, get everything straight like Larry said, and measure the offset YOU need for YOUR bike. Every bike/build is going to be slightly different and the offset of your bike may be different. The key is not to rely on what worked for someone else, but figuring out what's going to work for you. In my book, that's most of the fun! ;)
FRANKEN Z!
  • PLUMMEN
  • PLUMMEN's Avatar
11 Jan 2011 16:27
#421548
where have i heard this before? oh yeah same thing i keep telling him,but it hasnt sunk in! :laugh:
  • larrycavan
11 Jan 2011 16:33
#421551
I bought the 5/8 and ended up taking 1/8" off. It had a 1/8 shoulder on it so it was easy.
If you do this correctly, you shouldn't need more than a 5/8 off set. If you do, you screwed up somewhere along the way.... look it over again :lol:
  • kz1k
11 Jan 2011 16:49
#421559
once i get the rear sprocket, whats the best way to figure the offset....just a straight edge?
1978 KZ1000A2
  • kz1k
11 Jan 2011 17:16 - 11 Jan 2011 17:54
#421562
well until my rear sprocket shows.... i took the width of my kz rear sprocket, i measured from the inside of my sprocket hub and tightened my top hub nut to where i had the width of the rear sprocket between the nut and the hub face. i put the straight edge outside even with the inside of the hub nut, and square with the tire sides. i took a measurement at the front sprocket and this is what i came up with.......
1978 KZ1000A2
Last edit: 11 Jan 2011 17:54 by kz1k.
  • kz1k
11 Jan 2011 17:17
#421563
1978 KZ1000A2
