Stu Pidasole's Build
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: Joe's '78 kz1000 build
11 Jan 2011 17:18 - 11 Jan 2011 17:19
#421564
.......looks like the 5/8" offset sprocket is all ill need.
1978 KZ1000A2
Last edit: 11 Jan 2011 17:19 by kz1k.
  • kz1k
12 Jan 2011 06:07 - 12 Jan 2011 06:14
#421660
morning guys....i am looking at offset front sprockets for my mod. i noticed some come with nose? what is nose, and do i need one?
i called the sprocket company. they said the sprocket i need will come with a nose, but i dont need to use it.
Larry did yours come with a nose? and did you use it if it did?
1978 KZ1000A2
Last edit: 12 Jan 2011 06:14 by kz1k.
  • porchev914
  • porchev914's Avatar
12 Jan 2011 08:06
#421673
The nose is for an outboard bearing support like this
it replaces the stock procket cover and supports the end of the sprocket with an additional bearing. 5/8" offset is around the max you want to run without a bearing support, so you shouldn't need the plate I have. FWIW, I still have not ordered a front sprocket. It's not a critical part until I want the bike to move under its own power. :P
FRANKEN Z!
  • kz1k
12 Jan 2011 09:46
#421681
whats your offset adam? and what did that baby set ya back if ya dont mind....its awfully pretty. :)
1978 KZ1000A2
  • kz1k
12 Jan 2011 10:00
#421683
well i spent the morning cleaning a well needed garage......
1978 KZ1000A2
  • kz1k
12 Jan 2011 10:02
#421684
i found this rack the other day near the dumpster....came in handy....
1978 KZ1000A2
  • porchev914
12 Jan 2011 10:45
#421691
Joe, my offset is .920" or something like that. I have it written down with all the other measurements from my build in a little notebook. I used a line laser and set it up behind the bike on the centerline of the rear sprocket. Then I just measured from the stock counter sprocket to the laser with calipers. Easy as pie. The outboard bearing support I have was made by another member here named Irishwill. I think it was $110 or $120 shipped.......which was a steal.
FRANKEN Z!
  • kz1k
12 Jan 2011 11:03 - 12 Jan 2011 11:05
#421694
hell yeah that is a steal. nice buy. it looks great too.
when you shot the laser on the centerline of the rear sprocket, how did you know you were square on the center?
1978 KZ1000A2
Last edit: 12 Jan 2011 11:05 by kz1k.
  • porchev914
12 Jan 2011 13:59
#421734
The line laser "wraps" around the sprocket, so if I'm off one side or the other, the laser won't be centered on the sprocket teeth all the way around. But just to be sure, I made a mark on the swingarm near the pivot inline with the centerline of the chain run, just to be sure.
FRANKEN Z!
  • kz1k
12 Jan 2011 16:06
#421758
you have a link to this laser that "wraps"?
1978 KZ1000A2
  • PLUMMEN
  • PLUMMEN's Avatar
12 Jan 2011 16:13
#421760
well yeah,hes all over internet! :woohoo:
12 Jan 2011 16:15 - 12 Jan 2011 16:19
#421761
Is this one?
$20 line laser
Last edit: 12 Jan 2011 16:19 by 650ed.
