Nelson's KZ1000 Fighter? build
- Nelson
Re: Nelson's KZ1000 Fighter? build
23 Jul 2011 19:08 - 23 Jul 2011 19:12
:woohoo: The tire store airgun did it. you can see the problem area. What the heck caused that? rust? Just like it was welded.
Now I can finally look into getting the crank welded.
Attachment crankend.jpg not found
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
Last edit: 23 Jul 2011 19:12 by Nelson.
- Nelson
23 Jul 2011 19:10
I noticed the end has no woodruff key... I bought one that was in the parts diagram... :huh:
Where the heck does it go? Oh wait.. ignition maybe? Don't recall.
23 Jul 2011 20:15 - 23 Jul 2011 20:21Nelson wrote: :woohoo: The tire store airgun did it. you can see the problem area. What the heck caused that? rust? Just like it was welded....
Congrats!
9am53, take note.
www.kzrider.com/forum/2-engine/399151-kz...n?limit=20&start=340
Last edit: 23 Jul 2011 20:21 by Patton.
- Nelson
23 Jul 2011 22:57
dang! I guess it wasn't that bad... although I was starting to have scary thoughts about cutting the whole bloody rotor off!
- Nelson
24 Jul 2011 01:37
Oil pump checks out OK. Found a bit of sludge, but very little. Clearances are good. The Vesrah "complete" gasket kit does NOT have an oil pump gasket...
Look at all the purty parts! I'm using really coarse media that leaves a texture. This iron colored paint makes a totally cool look on that IMHO.
Attachment oilpump.jpg not found
Attachment covers004.jpg not found
Attachment covers003.jpg not found
- Nelson
24 Jul 2011 01:45650ed wrote: Fewer balls means lower load capacity. Ed
BTW - I bought a bearing from APE instead of using the odd one I had. Interesting price differences: APE $30, Bikebandit $82, Local bearing house $53.
- mark1122
- Keep twisting it
24 Jul 2011 11:04Nelson wrote: Oil pump checks out OK. Clearances are good. The Vesrah "complete" gasket kit does NOT have an oil pump gasket...
that is normal.
there used to be 2 dif thicknesses of gaskets available for the pump.if your clearance was loose , the thinner 1 would give tighter clearances and therefore more pump pressure. some guys would make up new 1's even thinner. u must be careful checking the clearance though. the manual says to use plastigauge,but that stuff can actually bow the cover and distort the measurement.so u need to make sure it doesnt bind if u change to a thinner gasket.i bought a few dif pumps and mix and matched the parts to get tighter gear , and wall,clearances.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Nelson
24 Jul 2011 13:03
THanks Mark. I called some autoparts stores and noone seems to carry gasket material that .006 thick (I measured the one I took out). It's all thicker. Where do I get the stuff? I should just order an OEM one I suppose.
- Nelson
24 Jul 2011 13:28
I imagine the goal is simply to make the clearance as small as possible. As it heats up the clearance probably increases because the aluminum body will expand more than the steel gears.
Heck, if the clearance is too tight it will probably grind of a bit of aluminum right away quick and then be as tight as possible! :laugh: It certainly won't seize, as it's driven by that big gear right off the crank.
- mark1122
- Keep twisting it
24 Jul 2011 21:24
check with the dealer and see what size /thickness they have. when i got 1 a few years ago it was the thinner 1.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Nelson
21 Aug 2011 15:19
Well my crank is still at the machine shop being welded and trued. While I wait I started cleaning up the wheels to paint them. BUT My bloody compressor just died... Dunno what's wrong yet. It just won't go on. As if the power is dead. Power is good, but it don't work!! The most important tool in the shop is down, so I guess I have to work on that now instead of the bike dangit.
- Chaotic Reason
21 Aug 2011 16:24
Busted Fuse? Isn't that always the case, the one tool you plan to use, and the only one you need to use for the work you plan to do, and it goes kaput! Sorry mate. Hope it's an easy fix.
Michael
1980 KZ1000 shaft drive
