Nelson's KZ1000 Fighter? build
- Chaotic Reason
Re: Nelson's KZ1000 Fighter? build
16 Nov 2011 07:53
Vacuums are our friends too!
Michael
1980 KZ1000 shaft drive
- testarossa
16 Nov 2011 09:05
Nelson, I can't remember off the top of my head, but I can check my spare set of cases when I get home this evening. I doubt it does.
BTW that color looks killer on your engine cases.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
16 Nov 2011 13:49
i am no help on the hole.
but i do like that paint on your cases !
16 Nov 2011 15:53
I would use the shop vac and a dental pick to carefully clean that hole. Ed
- jus1975
- www.tripleaperformance.com
16 Nov 2011 16:21
im not sure if it goes through but why chance the hard work. take it apart and clean it out. it may sound crazy but at least you wont worry about it later.
- testarossa
16 Nov 2011 17:27
No sense in tearing it apart when I have a set of bare cases that I will check for him in about two hours. If it's a blind hole then he can clean it out easily without splitting his cases.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- testarossa
16 Nov 2011 18:32
Nelson, I just checked my spare cases and that hole is blind. You should be able to pick it, blow it, or tap it. What ever method you prefer to get your holes clean. :whistle:
No worries about getting any gack into your crankcase there.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- Nelson
16 Nov 2011 22:48 - 16 Nov 2011 22:49
super awesome! thanks testa!
yeah I really dig that color too :woohoo:
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
Last edit: 16 Nov 2011 22:49 by Nelson.
- hal0tw0
17 Nov 2011 18:13
I dig the color too! ducati-ish.
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- Nelson
27 Nov 2011 03:11
Ok I got the hole cleaned out and that cover on. Now I'm trying to decide what to do about this rubber damper thing for the starter clutch. I did the clay measurement in the manual.
Clearance is 7mm. The old damper is 7.26mm thick and has the 2 star marks on it.
The manual says for clearance of 6-7mm use the 2 star damper, for clearance of 7-8mm use the 3 star (thicker) damper.
My clearance is right on the line between the two. How to decide?
Manual says new dampers are 7.3mm or 8.3mm.
Any thoughts?
Any thoughts?
Attachment damper002c.jpg not found
- Nelson
27 Nov 2011 03:47
also - who's got a new needle bearing for that? Bike Bandit did not, and I think Z1 didn't either, but don't remember for sure...
- mark1122
- Keep twisting it
27 Nov 2011 09:27
since u are so close, it shouldnt matter.
i would use the damper u have . it may get a little tighter when u torque it .
if u use the thicker 1, it will just ware faster.
did u try your local kawi dealer for the bearing? not sure if they actualy ware out. if there is no obvious ware i would run it. if we can leave the crank bearings in for so long i think we can leave those.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
