Nelson's KZ1000 Fighter? build
  • Nelson
  • Nelson's Avatar Topic Author
Re: Nelson's KZ1000 Fighter? build
23 Oct 2011 22:12
#484969
thanks, I was kinda thinking the same thing. gotta make sure the oil pump gear clears the new weld also. It's almost flush so I think it's Ok.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • Nelson
25 Oct 2011 01:36
#485199
I did the dry assembly and everything seems fine. The trans won't shift into 2nd or higher, but I think this is normal because of the 3 balls in the trans shaft which are not spinning right now... anyone? :huh: First and neutral shift normally.
I still can't decide if I'm leaving out the kickstart shaft.. :S no time left to decide :pinch:
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
25 Oct 2011 03:23 - 13 Feb 2012 18:03
#485214
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 18:03 by KZ250LTD.
  • Harvey1327
  • Harvey1327's Avatar
25 Oct 2011 05:04
#485231
I can see a major problem. :(
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
  • jus1975
  • jus1975's Avatar
  • www.tripleaperformance.com
26 Oct 2011 00:37
#485379
that o-ring in the middle. Is that a regular metric o-ring. I cant find it in the parts diagram.
  • Nelson
26 Oct 2011 00:41
#485382
huh? what does that mean?
  • Nelson
26 Oct 2011 00:42
#485383
oops, i was responding to Harvey
  • Nelson
26 Oct 2011 00:44
#485384
jus1975 wrote: that o-ring in the middle. Is that a regular metric o-ring. I cant find it in the parts diagram.
It's the oil passage seal. it's not an o-ring, it has a flat side and a beveled side. I believe there's one under the oil pump also
  • Harvey1327
26 Oct 2011 05:41
#485417
Nelson wrote: oops, i was responding to Harvey
It's so clean and shiney, and your gunna close it up and throw oil in there.
:laugh: :laugh: :laugh: :laugh: :laugh: ;)
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
26 Oct 2011 10:23
#485431
Nelson wrote: Ok I'm finally ready to put this together. These pics are shot just before assembling the case halves. Please look to see if I forgot anything.
Dowel pins are in cases and alignment pins for all the bearings. New HD Cam chain is in. noew oring for oil passage, etc.
These pics are hi res, so you can click on them to see more detail. A response is appreciated! :)
Attachment readytoassemble003.jpg not found
if its not too late. have a look at the springs in the back of the clutch basket. in time they ware on the housing and get tired and loose. they can even brake.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Nelson
16 Nov 2011 03:15
#488718
OK I finally got something done. The bottom end is mostly together now!! :)
Attachment bottomendassembly002c.jpg not found
  • Nelson
16 Nov 2011 03:20
#488720
Does anyone know if this hole leads into the cases? I missed it somehow when blowing out media... :angry: I'm hesitant to blast air into it in case it's just going to get pushed into the case. There's so much crud that I can't tell if the hole has a bottom or not. Grrrr... I spent soooo much time blasting and cleaning everything.... :S
Attachment bottomendassembly001c.jpg not found
