Nelson's KZ1000 Fighter? build
- wireman
Re: Nelson's KZ1000 Fighter? build
13 Jun 2011 07:01they only leak oil when you dont put em together right! :woohoo:mark1122 wrote: KZ's like to leak oil . i allways felt the hd studs work in your favour to helps with the leaks , since they alow higher torque specs. 42 rather than 30 ft lbs.
- Nelson
13 Jun 2011 22:39
So making my own gaskets out of cereal boxes and elmer's glue is a bad idea?:silly:
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- wireman
14 Jun 2011 08:37
just use copper coat in place of glue! :woohoo:
- mark1122
- Keep twisting it
14 Jun 2011 08:39testarossa wrote:Nelson wrote: Thanks Mark. you're full of all kinds of good info.
That's not the only thing he's full of. :ohmy: Sorry, buddy, I had to.
wre u going to say full of love ? :laugh: Thanks Pal. :laugh:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
14 Jun 2011 08:48 - 14 Jun 2011 08:49wireman wrote:they only leak oil when you dont put em together right! :woohoo:mark1122 wrote: KZ's like to leak oil . i allways felt the hd studs work in your favour to helps with the leaks , since they alow higher torque specs. 42 rather than 30 ft lbs.
:laugh: :kiss:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 14 Jun 2011 08:49 by mark1122.
- Nelson
15 Jun 2011 02:10
I put a couple things in the "parts washer" today...
They came out nice and oil free ready for media blasting. Of course I cleaned off the worst of it before doing this.
Attachment bottom-end-016.jpg not found
Attachment bottom-end-017.jpg not found
- wireman
15 Jun 2011 02:15
reminds me of my first apartment i had way back when! :woohoo:
- Nelson
15 Jun 2011 02:15
The stupid rotor is still stuck!!!
I heated inside it a bit with propane. Then I used the perfect size bearing and beat hell out of it with the airgun and hammer. I'm getting worried about stripping the threads in it if I keep using the airgun like this.
what to do? Maybe stand it on end and let some lube soak in overnight. Damn the crank is heavy! like it's made a steel or somethin' :blink: :laugh:
- mark1122
- Keep twisting it
15 Jun 2011 08:55
is it possible that your air gun dosnt have enough oomph ? maybe u could take it to a garage and let them give a shot with a high powered air gun ?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
15 Jun 2011 10:51 - 15 Jun 2011 10:52mark1122 wrote: is it possible that your air gun dosnt have enough oomph ? maybe u could take it to a garage and let them give a shot with a high powered air gun ?
x2 What size air compressor are you using, and what size fittings/air hose are being used on the air gun? Maybe you aren't getting the most from your air gun or you need one of those big daddy 3/4" drive airguns to do the trick. I also wonder if the bolt you are using might not be too long. If it's very long, then it acts like a torque stick and limiting the actual torque transferred to the rotor. Maybe try a shorter bolt. I know I used the top bolt from the upper triple clamp as suggested in the service manual. It's only just long enough to do the job.
EDIT: I forgot to mention that I love the dishwasher/parts cleaner thing. Can't tell you are single. Mamasan would have my ass if she caught me doing that stunt.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 15 Jun 2011 10:52 by testarossa.
- Zedone
15 Jun 2011 13:46
Nelson, was this crank ever in storage for long periods of time out of the crankcase? Also (it may be a long shot) but do you see any evidence of red loctite around the end of the crank, I'm wondering if a previous owner may have went nuts using loctite or JB weld :blink: between the alt & crank on the mating surfaces for some reason. The only other thing I can think of is that the end of your crank could have been machined previously if the crank surface is somewhat rough and it has seated your alt on there pretty good. Hang in there, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- Nelson
15 Jun 2011 23:07
I don't think the crank has been outdoors and rusting. Can't see loctite, but anything is possible. I'm pretty sure the gun is cranking out plenty of torque because the bolt mushroomed just a tad and became harder to get out.
I'd really like to replace the rubber damper thing behind the starter gear and maybe get the crank welded, so this thing needs to come off!
