Nelson's KZ1000 Fighter? build
  • Nelson
  • Nelson's Avatar Topic Author
Re: Nelson's KZ1000 Fighter? build
29 May 2011 02:05
#454083
hey that's not what I want to hear! :ohmy: :P
Consider that the bike will always be an occasional weekend rider and it's unlikely I'll put even 1000 miles a year on it...
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • wireman
  • wireman's Avatar
29 May 2011 02:10
#454084
well you could always just slap new seals on it and get used to a little smoke when you start it up or back off throttle as the seals get banged up B)
  • Nelson
29 May 2011 02:44
#454090
now you're speakin' my language :laugh:
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 May 2011 10:25
#454134
the manual says to replace guides if they measure .004" in that test.
new is .0008" to .002" int, and .0012- .0024 exht.
now its your call. ;)
if u dont mind taking it apart again latter, u could run it for a while and make a judgment call on your findings. if u dont want to take it apart latter, then do them now. if u change the guides u will need a valve job. then u may as well send it to Larry for a complete job with porting. :)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Nelson
29 May 2011 13:15
#454176
thanks Mark. yeah I kinda figured if I do the guides it means I end up having to spend a bunch of money to do the whole head... I think I'll put that off for a while. I must remind myself that this was a perfectly good running engine with good compression when I took it apart. I think lapping and seals will do for now.
  • kzr750r1
  • kzr750r1's Avatar
29 May 2011 14:05
#454180
Nelson I hope you don't regret putting it off like I have.
Yeah mine is running without but wish I didn't cheap out when the motor was apart last time.
Just opening it up again after rebuild will cost some more in time and gaskets ect. ect.
Shame to hear Larry is gone from the site. I will miss his input.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
  • Nelson
30 May 2011 01:46 - 30 May 2011 02:45
#454297
yes that is a good point. I wish I had all the tools to do the head myself. I did valve jobs years ago (with other people's cutters and such) but I think those things are pretty darn pricey and it doesn't make sense to buy for the little use I would give them.
Let's see. I'd need stuff to replace and ream guides, then cut seats. Hmmm. I wonder how many hundreds that would cost... it would be great to have that stuff.
Last edit: 30 May 2011 02:45 by Nelson.
  • Nelson
06 Jun 2011 01:35
#455723
I decided to stop thinking about the head and take the rest of the engine apart. Got the cases split yesterday. All the engine side covers were a bear to get off. I had to heat them, bang them and tap a razor blade in the gasket area bit by bit to get the thing apart. Heck splitting the cases was easier than all the covers because Kawi gives us that nice built in splitter. I'm impressed with how beefy the clutch is. Heavy steel basket, tons of plates, very different from the dirt bikes I'm used to working on.
Attachment splitcases007.jpg not found
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
06 Jun 2011 09:43
#455749
i just love the way the inside of a kz 1000 looks :woohoo: !
  • Nelson
06 Jun 2011 22:43
#455854
yeah maybe I'll just set it out on the coffee table for a while...:lol:
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jun 2011 09:39
#455907
haha,thats what makes us gearheads!
:dry: i thought it was,uh
on the coffee table !!!!!!:whistle:
  • Nelson
08 Jun 2011 01:35
#456056
OK how do I get this rotor off? Clearly I should have thought of it before I took the engine out of the frame. The clymer manual says put a ball bearing in the hole and tighten a bolt on it. Well the hole on the end of the crank swallows up the bearing so....? Maybe I need a bigger ball bearing.
Is it safe to just put the bolt in and hit it with the air gun? I don't wanna mess up the end of the crank. Anybody know?
Maybe if I grind the end of the bolt really flat it would be less likely to cause damage.
Attachment rotor.jpg not found
