A Newbies Adventures in Maintenanceland!
  • 9am53
  • 9am53's Avatar Topic Author
  • homebrew, and some bbq
Re: A Newbies Adventures in Maintenanceland!
20 Jan 2010 05:22 - 20 Jan 2010 05:23
#343590
I finished my valves last night, and followed OMR's recommendation of getting the cam caps in and torqueing the valve cover on to set the caps, and hopefully in the next couple days I will go back and put the valve cover gasket on for good.
I also pulled the rear wheel off, and tried to follow the instructions on removing the bearings. I took the sprocket housing thing off, removed the grease seals from both ends, removed the circlips, but I can't seem to make the bearings budge. I tried mainly to remove the bearings from the wheel portion, so like I said I had the clip out, and followed the instructions and banged on the inner race on the bearing on the disk side of the wheel. After several minutes of banging it wasn't moving so I didn't want to force anything and quit...do I need to heat the rim to remove the bearings? Would it not make more sense to bang on the outer race of the bearing since it is what is seated in the rim?
Last edit: 20 Jan 2010 05:23 by 9am53.
20 Jan 2010 06:55
#343594
I would soak the outer race, where it contacts the wheel, with Kroil for a couple days then drive the bearing out using a drift against the outer race. Ed
  • 9am53
20 Jan 2010 07:52
#343596
Thanks Ed, I have pb blaster so I'll use that. Does my manual have another mistake in telling me to bang against the inner race? forgive my ignorance but what is a drift?
20 Jan 2010 19:27
#343697
Banging against the inner race drives it against the steel balls and them against the outer race. This will damage the bearing surfaces of both races by creating dimples in the races. Banging against the outer race doesn't apply any pressure on the steel balls or bearing surfaces on which the balls roll so there is no damage. This may not matter a great deal when removing old bearings that are going to be discarded, but you should never bang on the inner race of bearings, such as the new ones, that you plan to use. By "drift" I meant a steel or brass rod used to drive out the bearing. Ed
  • 9am53
21 Jan 2010 05:22
#343730
Thanks, the bearings seem to smoothly spin still, but I think I should now replace them that I likely have damaged them. I was supposed to go ice fishing tonight, but I am kind of interested to see if I can get the bearings out with a few solid hours dedicated to it. I will check it out tonight and post results. Hopefully I get it apart, otherwise I am a total bonehead! lol
  • Old Man Rock
  • Old Man Rock's Avatar
21 Jan 2010 06:28
#343734
BTW... Where's all the images as you go through each phase....?
What, don't they have digital photography technology up there in Canook land.... :P :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • 9am53
21 Jan 2010 06:32
#343735
yeah, I have been kind of skimping on the photo side of things...we do have cameras here, but I need a cartridge for my polaroid :) My gf has been hogging the camera and everytime I head over to work on the bike I forget to take it back...
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
21 Jan 2010 19:40 - 21 Jan 2010 19:42
#343838
9am53 wrote:
I also started adjusting my valves, all are good, exhaust are 0.08-0.1, and my intake are all going to be 0.05-0.08, although I may have to go buy one shim from the shop because one valve is being frustrating.
If you've had the valves/head done (I don't recall), make sure to account for seating. The clearances will decrease a small amount (.001 - .002inch in most cases) as they wear in.
I go closer to .1mm on intake, and .15mm exhaust as they will tighten up more due to heat.
Cheers, n Good Luck... from Florida :laugh:
B)
OMR, feel free to flame the Canuck Conversion! (inch - mm's) :woohoo: :laugh: :P
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 21 Jan 2010 19:42 by TeK9iNe.
  • 9am53
22 Jan 2010 04:27
#343870
B)
Actually I unintentionally and preemptively took your advice. Just before I put the valve cover on I decided to check all the lashes one more time just to be sure, turns out that rotating the cams around a few times seated the shims a bit and all my clearances loosened up a bit, so my intakes are all .08ish and my exhausts are all .12-.15. And you know what we should flame ourselves for our canuck conversion...I weigh 265 pounds, I don't know what that is in kilos, you buy deli meat in hundreds of grams, it is 275 km to Toronto, but my boat is 19 feet long...I think this fencepost is enlarging my butthole!
  • Old Man Rock
22 Jan 2010 04:53
#343879
"I weigh 265 pounds, "... :blink: Poor KZ.... :P
You better be as tall as Craigy you fat basterd....
Oh wait, long winters up there eating Caribou and twinkies... My bad.... :S
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • 9am53
22 Jan 2010 05:00
#343882
haha, poor kz for sure, last summer I weighed 320 pounds and I did a fair bit of cruising around the province with my not-so-skinny gf and bags full of stuff. You should have seen us on the REALLY poor 550 spectre! Thank god for wet clutches! Luckily I am 6'5" so I don't look like a blob, I also have hair to the middle of my back and a big red beard, so I look like a viking! broads love it! lol I don't eat twinkies, I prefer funnel cake :)
  • Old Man Rock
22 Jan 2010 05:22
#343891
6'5"... wholly carp your up there with Craigy then....
Damn, I need to go ride/camp with you two, tie ropes to both of your necks to set up my hammock.... Sweet! :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
