A Newbies Adventures in Maintenanceland!
- 9am53
- homebrew, and some bbq
Re: A Newbies Adventures in Maintenanceland!
08 Jan 2010 04:30 - 08 Jan 2010 04:32
I went to take some pics of my tank and covers, but my buddy (the guy who own the house where my bike is at) wasn't home, so I couldn't get in his house to take the pics. All my paint and paintables are inside as well, so I couldn't really do too much in that vein. My propane tank ran out as well, so I could only last in there for a half an hour. I did manage to do some polishing and took some pics. I cleaned out the "KAWASAKI" logos with alcohol and filled them in with nail polish. Plummen said to use sharpies, and that woulf have been easy, but I wanted that enamel glossy look. I dropped the polish into the letters, and it filled the leter in on it's own, so I didn't really need to do much painting, it was just a matter of "dripping between the lines" as it were.
There are a couple spots on the clutch cover in particular where I got some polish outside the letter, I will now clean it off the smooth polished top with a razorblade. I am not sure if originally the 1N2345 part had a black background, but I filled it in as well, and I think it looks good, and hope it will last!
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
Last edit: 08 Jan 2010 04:32 by 9am53.
- 9am53
14 Jan 2010 05:27
I went to put on my nice and polished clutch cover on, so when I put the clutch back together I broke another bolt (One of the bolts that hold the springs)...I had the bolt remover from when I broke a bolt in the head so I got it out no problems. I went to the Hardware store and found a perfect replacement for the bolt and thought I might as well replace all 6 of the bolts to keep it balanced. Is it OK that I use the shiney zinc plated bolts from the hardware store instead of those black bolts that are were in there originally? The Zinc ones are steel too right, so they are strong enough I assume.
Once I get my shims in I will get started on some chassis maintenance, so I will start posting more again.
'84 GPz900r
'71 CB350
'71 CB350
14 Jan 2010 10:43 - 14 Jan 2010 10:45
9am53 wrote:
Earlier model large fours used 78~95 in-lbs torque on the clutch spring bolts -- inch-pounds. If not already done, would double-check FSM for the particular bike at hand to assure applying correct torque to the clutch spring bolts.
Am unaware of the specific oem bolt specs, but don't think the zinc plate would do any harm (although the bolts aren't in a rust-prone environment).
Good Luck!
Good Luck!
Last edit: 14 Jan 2010 10:45 by Patton.
- 9am53
14 Jan 2010 10:47
yeah, it's 76 inch pounds I think, I am going to get another torque wrench...I used a zinc bolt in my head too, buying and shipping the OEM bolts would cost me at least 10 bucks to canada and take a couple weeks, I like 1.70$ today at the hardware store better
'84 GPz900r
'71 CB350
'71 CB350
- TeK9iNe
- What did you do!?!
14 Jan 2010 16:13
Man stop breakin' dem bolts :laugh:
Your OK to use those bolts. No problems, they'll hold just fine.
I would go stainless if you can find them for anything on the outside.
All the covers on your bike need only have the bolts snugged really. Just enough to prevent a leak, and it doesnt take much really. 90 inch-pounds or so...
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
14 Jan 2010 17:24
Don't hardware stores up there have SS or grade 8 bolts?
Same time, sooner or later your going to bust one you can't get out.... Cheap bastard, spend the $10....
And it's INCH Pounds for christ sakes.... Lay off the muscle on the torque wrench.... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
14 Jan 2010 18:18
Old Man Rock wrote:
grade 8 for inch pounds?......a tad bit of overkill?
..:woohoo:
- 9am53
14 Jan 2010 18:23 - 14 Jan 2010 18:24
10 bucks aint the main thing, the time to ship is the worst part. It's the middle of January and just today I got 6 shims in the mail so I can (hopefully) finish the motor and move on. I still have a lot of work to do on the bike and if I shipped everything up here to canada (which takes usually between a week or 2) I would be missing some of the early riding in april/may. I expect Mr. Saunders' Neighborhood will be getting at least 3 more rounds of orders from me before the winter is done, assuming Z1E gets it here fast (which they usually do) I have at least 3 weeks of downtime, if anything is not in stock that time goes up.
I still want to clean up and grease wheel bearings, paint my rims, rebuild brake calipers, install new ss lines with my new zx10 master cylinder, remove those twenty pound aluminum footpeg holders and install (figure out) rearsets, possibly put on new sprockets, finish paint, clean up electrical, perform the WGCM, errrrr, I mean the OMRCM
find a new headlight, make a custom brakelight for my newly to be installed ducktail, and track down some rear turn signals...damn, that sucks. I have a feeling my newly built ice-hut won't be seeing too much of me this winter...
p.s. is it a good idea to blue-loctite every bolt I put in that I don't intend on removing anytime soon?
'84 GPz900r
'71 CB350
'71 CB350
Last edit: 14 Jan 2010 18:24 by 9am53.
- Old Man Rock
14 Jan 2010 19:30
"a tad bit of overkill"...
Not the way he torques bolts... :blink: :huh: :dry: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 9am53
15 Jan 2010 04:31
Old Man Rock wrote:
Hey now, Women usually like how I tighten bolts!
Not to deflect blame, but could the fact that my motor is in a cold garage (as in by the time I am turning wrenches it is up to maybe around the freezing mark after an hour of heating) have something to do with my bolts breaking? Not too many more bolts to tighten so I have to find another way of messing things up! lol
'84 GPz900r
'71 CB350
'71 CB350
15 Jan 2010 15:01
9am53 wrote:
Imo, "anti-sieze" is sometimes a better choice.
Good Luck!
Good Luck!
- 9am53
16 Jan 2010 19:31 - 17 Jan 2010 11:16
I went to put the new bolts into my clutch pressure plate only to realize that the washers seem to be much smaller than the threads on the bolts, so I can;t take the washers off the bolts, or put the washer on the broken bolt onto my new bolt. Should I just go buy new washers that are close to the right size? or is there a special way to get them apart?
EDIT: Never mind, I drilled out the hole on the one offending washer and just kept the old ones in there. Worked out good, I now have the clutch cover and it looks good. I also started adjusting my valves, all are good, exhaust are 0.08-0.1, and my intake are all going to be 0.05-0.08, although I may have to go buy one shim from the shop because one valve is being frustrating.
'84 GPz900r
'71 CB350
'71 CB350
Last edit: 17 Jan 2010 11:16 by 9am53.
