A Newbies Adventures in Maintenanceland!
- timebomb33
Re: A Newbies Adventures in Maintenanceland!
19 Dec 2009 11:02
i normally set up my engines to use .004" on the intake and .006" on the exhaust. seems to work pretty good for me.
I THINK MY POWERBAND BROKE
- TeK9iNe
- What did you do!?!
19 Dec 2009 12:57
.004 intakes, .005 exhausts.
Don't worry too much about perfect accuracy right now, cause you will be back in thier soon enough to check/change some out again.
Tight tolerances are great for making power (if you want), you'll just have to check/change more often.
Too tight = :S Compression loss, burnt valve, poop.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
19 Dec 2009 13:10 - 19 Dec 2009 13:14
9am53 wrote:
A1: CORRECT - big no-no. It will mark up the cam lobes BAD.
A2: You need to have shims in place before tightening down any cam caps so as not to damage the cam lobes on the sharp bucket edges.
I would swap shims with the caps properly torqued down, so you don't change the gaps/tolerances accidentally.
This is also part of the reason why after some kms, you'll have to get back in thier and check/change shims, and torques. Heat and expansion are going to make things change.
Cheers!
Turning the crank without having the shims on top of the buckets is a big no-no right? would it be a good idea to take the cams out before I do the shim swapping?
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 19 Dec 2009 13:14 by TeK9iNe.
- Old Man Rock
19 Dec 2009 16:05
"use .004" on the intake and .006" on the exhaust."...
Well I wish you Canooks would make up your damn mind....
You want freaking metric then you recommend in inches.... :laugh: :laugh: :laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- timebomb33
19 Dec 2009 16:26
who the hell said we wanted metric, i do all my clearance measurments in standard always have i do know this for sure 1 mm is .040" i convert back and forth all the time. also each shim size is about .002".
19 Dec 2009 17:21 - 19 Dec 2009 17:21
Here's one of the several handy quick conversion web-sites.
No math required. :laugh:
www.onlineconversion.com/length_common.htm
Good Luck!
Good Luck!
Last edit: 19 Dec 2009 17:21 by Patton.
- TeK9iNe
19 Dec 2009 18:59 - 19 Dec 2009 19:00
Old Man Rock wrote:
:laugh: :laugh: .10mm on intakes, .005inch on exhausts.
Just to clarify. :woohoo:
PS. its Canuck! :silly:
Well I wish you Canooks would make up your damn mind....You want freaking metric then you recommend in inches.... :laugh: :laugh: :laugh:
OMR
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 19 Dec 2009 19:00 by TeK9iNe.
- 9am53
- homebrew, and some bbq
19 Dec 2009 20:37
TeK9iNe wrote:
yeah, Crazy Canucks....who keep getting injured before the olympics....damn skiers
Tomorrow I will do what swapping I can, that motion pro tool works about as well as a butter knife for cutting sushi. I think I will have to get the hang of it. I understand why too tight is bad (for tolerances anyway) but how is too loose bad (again, for tolerances :S ) would too loose just mean the valves are not opening enough?
Old Man Rock wrote:"use .004" on the intake and .006" on the exhaust."...
OMR
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- PLUMMEN
19 Dec 2009 22:22
yep,but too loose is still better than too tight
- Old Man Rock
20 Dec 2009 06:35
can-cooks....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
20 Dec 2009 08:31
Old Man Rock wrote:
well as a matter of fact i do cook everything out of a can! :laugh:can-cooks....
- TeK9iNe
20 Dec 2009 19:33
:laugh:
Too loose is OK. But valvetrain will be very noisy. You'll get that cold lifter sound... TAP-TAP-TAP-TAP-TAP-TAP-TAP... very annoying.
Remember, when checking the clearances, press the feeler gauge perfectly flat to the shim hard (by bending it), then attempt to slide it under the cam. If you just try to push the gauge in at an angle, often it will jam and make you think there is no gap.
Ahh, back in the newbie days...
Hope this helps!
Cheers.
Hope this helps!
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
