A Newbies Adventures in Maintenanceland!
- TeK9iNe
- What did you do!?!
Re: A Newbies Adventures in Maintenanceland!
05 Dec 2009 17:41
9am53 wrote:
Won't hurt nuthin.
Lookin gooood
Once I have the cams on and am setting the timing etc. I can turn it by the crank nut AND a little help by twisting the clutch basket? that seems logical now that I think about it. THis can't hurt anything?
Won't hurt nuthin.
Lookin gooood
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- keith1
05 Dec 2009 18:37
9am53 wrote:
nice color........
Tonight I took it easy and dust did a trial run on the painting.
I like the colour, what do you think? I have an effex clearcoat as well that is under one coat of the metalcast, so it is not popping out as much as it does on the top, I like it more subtle, I'll check it out in full daylight. Anyways, I will strip this off and do it properly now that I know I like the look.
nice color........
- PLUMMEN
05 Dec 2009 21:08
i like the color also.
id say spend more time on prep though,might i suggest letting paint dry for a few days before you sand it down other wise it might be a sticky mess.im no painter but it looks like youre not getting enough overlap as youre painting,which is causing the dark streaks
- 9am53
- homebrew, and some bbq
06 Dec 2009 14:29
I didn't sand the paint off, I took my heatgun to it, it works like a charm, especially since the paint wasn't fully cured. The dark streaks are actually from over prepping it. I have refinished several guitars, all using nitrocellulose lacquer, and with lacquers you really have to sand everything smooth between coats because as the paint dries (over months) imperfections will slowly appear. The paint I used on the bike was duplicolour Metalcast. After adhesion promoter and primer you spray some "ground coat" which is like a metallic silver base coat which shines through the translucent green giving an anodized look, kind of like a candy coat. I sanded the ground coat smooth before the green assuming it was just like the lacquers I am used to, but in fact the instructions say not to sand, and to spray the colour coat within 1 hour of the ground coat. Since I sanded the silver ground coat I ended up smoothing out some of the metal flakes causing they to sit flat instead of stand up like they are supposed to to give the metallic effect. Under different light the dark streaks and light streaks interchange. I am glad I did a practice run, as now I know how this stuff works, and my next time will look really nice.
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- PLUMMEN
06 Dec 2009 17:05
cool!
- Martynbiker
- 1993 KZ1000P
06 Dec 2009 18:53
9am53 That is a gorgeous Green! I can't wait to see it on the Bike!
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
- Locozuna
06 Dec 2009 19:19
One of the better greens I have seen. Nice!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Old Man Rock
07 Dec 2009 04:27
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 9am53
07 Dec 2009 05:24 - 07 Dec 2009 05:28
thanks boys! I need to get some more propane tonight to heat the garage, and I will start stripping the tank with my heat gun. I can't wait to see it either!
Upon spraying the fairing I got some overspray on the inside and realized I never thought about what I will do it the inside of it. I am not sure if I want to spray it too, or clean it up after and leave it black...any opinions?
'84 GPz900r
'71 CB350
'71 CB350
Last edit: 07 Dec 2009 05:28 by 9am53.
- 9am53
09 Dec 2009 14:17
I got my stuff from z1 today and before I put the head on, is there a particular side that goes up or down on the head gasket?
'84 GPz900r
'71 CB350
'71 CB350
09 Dec 2009 14:47 - 09 Dec 2009 17:08
9am53 wrote:
Folded over middle edges upward.
Good Luck!
Good Luck!
Last edit: 09 Dec 2009 17:08 by Patton.
