A Newbies Adventures in Maintenanceland!
- PLUMMEN
Re: A Newbies Adventures in Maintenanceland!
09 Dec 2009 14:53
i was gonna call it the crimped side but i guess that works! :laugh:
- timebomb33
09 Dec 2009 16:19
it's actually called the fire ring
I THINK MY POWERBAND BROKE
09 Dec 2009 17:01
timebomb33 wrote:
You're just rubbing it in 'cause I missed that one on your last pop quiz. :pinch:
[Click on image to see flaming cat]
- keith1
09 Dec 2009 17:03
timebomb33 wrote:
or if you like your mexican food hot, ring of fire....:laugh:
09 Dec 2009 17:27
Here's keith1 as he flunks the fire ring final exam. :laugh: :laugh:
[Click on image to see tb dial 911]
- 9am53
- homebrew, and some bbq
10 Dec 2009 19:00 - 10 Dec 2009 19:10
I just got in, damn it's cold out there, 70 kph winds and -15 with windchill...my bike is in a drafty old garage, so even with the heaters turned up to max there is noway I was painting tonight. I did get my last remaining valve in, and put my recently acquired block/head o-rings and head gasket on. I also did some more prep work on the painting front.
I mentioned in either this thread or my overlapping oil ring thread that I put a bit of a gouge in the top of one of my cylinders, well here it is. I put the head on now so I will see how it will fare, do you think it will be ok?
Anyways, going to bed to watch some Dexter now...then read the Bourne Identity, L8er
p.s. I was reading about when I put the head nuts back in that the copper washers go at the corners where the oil stud galleys are. The manual says that if the washers are worn or damaged to get new ones as they act like a gasket. Could I reuse the old ones and dab a bit of gasket goo on them to seal the studs better?
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
Last edit: 10 Dec 2009 19:10 by 9am53.
- Galactica
10 Dec 2009 19:24
Don't be so cheap!! If you can get em easy, and the book says replace em. Then replace em. You're in way too deep now. You don't want to tear it apart again later to replace some washers when YOU COULD BE OUT RIDING!!
R
R
77KZ1000
76 KZ900
76 KZ900
- 9am53
12 Dec 2009 15:17
ok ok, I won't be so cheap! I feel bad now...haha! anyways, I put the head back on (with new copper washers from the stealership!) and noticed that I didn't have any washers for under the head bolts...the 2 little bolts. I don't think they were there before, but I think I need a washer between the steel bolt and the aluminum head right?
Next is putting the cams in! hell yeah, I have been looking forward to this for a while now!
'84 GPz900r
'71 CB350
'71 CB350
- PLUMMEN
12 Dec 2009 15:35
heat the copper washers up cherry red with a prpoane torch and toss em in a bucket of water or snow bank or your beer,anything cold and watch em grow to origional size. then you can reuse them with no goop
- 9am53
12 Dec 2009 15:50
crappy, I went out and bought new ones...ah well. Are there supposed to be washers under the bolts? the manual doesn't mention them
'84 GPz900r
'71 CB350
'71 CB350
- keith1
12 Dec 2009 16:03 - 12 Dec 2009 16:04
9am53 wrote:
nope and dont go bannanas on em.... just snug em up good.....
Last edit: 12 Dec 2009 16:04 by keith1.
- 9am53
12 Dec 2009 16:18
ok thanks Keith!
'84 GPz900r
'71 CB350
'71 CB350
