- Thank you received: 109
OMR: '76 KZ900 Restoration/Modification
- mark1122
- Keep twisting it
Now lets get messy with that lube.
Are u going to use 2 base gaskets?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Thank you received: 104
- kpier998
Thanks for the information.
Kirk
- Old Man Rock
- Thank you received: 225
I had used clean motor oil as written in my shop manual but as explained by these 2, it will take some time before the oil pump/pressure build up gets the oil flowing to the head so use lifter lube! They basically called me a retard that I am...:blush: :laugh:
I explained to them I will accomplish their friggin
After some wear in time, will be replacing the shims and shooting for .004" on intake and .004" - .006" on exhaust on the Valve to Shim measurements...
Due to MRE once again... I had to use two .20" base gaskets (Permatex Copper gasket spay between & outer gasket) to get the piston to cylinder decking at 0 degrees, same height! If required (Oil leaks)I will use one .034" base gasket. In caliper measuring the two gaskets together, came out .035".
Head work was accomplished by the man himself... Larry Cavanaugh!
The guides where purchased over at APE...
HIGH PERFORMANCE BRONZE VALVE GUIDES
APE valve guides are designed to take the abuse of today's modern high horsepower engines. They are made from special bronze alloy to resist wear and heat.
APE guides are precision machined with the bores finished to size. They are designed to fit lower in the head to clear high lift cams, and use APE seals or factory OEM seals. Sold in sets of 16
VGK900 Kawasaki 650 thru 1100 2 valve $67.32
kzzone.com/valves.html
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Old Man Rock
next time i will drive to arizona and build his motor while he polishes a bunch of aluminum parts for me!
Well you old bastard, why didn't you say that in the first place..... Would of saved me a whole lot of headaches.
:laugh: :laugh: :laugh: :laugh:
After re-checking torques and valve clearances, going to order 240 for the intakes and swap the 235 over to the exhaust. This should drop me ~ .05mm specifications...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- JBKZ9
JB
- PLUMMEN
wow,why didnt i think of that?:laugh:next time i will drive to arizona and build his motor while he polishes a bunch of aluminum parts for me!
OMR
- shighley
Hey OMR; Can you elaborate on this statement? As you know, I've got the same kit sitting on the bench waiting. Did they mill the deck surface too much? Thanks from Lake Elsinore, ride safe, SteveDue to MRE once again... I had to use two .20" base gaskets (Permatex Copper gasket spay between & outer gasket) to get the piston to cylinder decking at 0 degrees, same height!
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- Old Man Rock
Yup.... I installed a new cylinder base gasket of OEM sizing .020".
Due to warpage of the head, Larry C had the head decking milled .003". Very minimal...
With cylinder, head, camshafts, timing components, tensioner etc... installed and all torqued down, I couldn't get a 360 rotation of the crankshaft (slowly, manual by hand mind you)... Something was bumping/hitting...
Stripped her part and noticed some extremely minimal circular (Valve) imprint on the piston dome. WTF!!!!
Got out the caliper and compared heights between original cylinder and new refurbished MRE cylinder... More than .010" milling of the new one... Go figure, MRE got me again....
Due to old age/warpage, oil build up etc... of the old original, measurements varied between .015" to .025" shorter on measurements around the new cylinder. With this in mind and since I had already squished one down and had another .020", two together gave me ~ .035" thickness.
Plummen provided some advice (Permatex Copper spray gasket maker) the two together for the .035" and try her out... No more bump! :woohoo:
Valve to Piston Heights:
Int: .030"
Exh: .060"
Schintz racing has .034" gaskets... If problems such as oil leaks arise then I will go with the one piece.
I had PM'd Tony about this to confirm his overstock kit wasn't screwed up, I felt really bad for I turned some of you onto these kits... Tony stated nope, all good in his kit.
What I've learned from this... with your new pistons installed, compress the cylinder down to 25 ft lbs via some stud sleeve's or such and insure the outer piston top edge is not above the cylinder decking.
Mine was about .010-.013" higher between all piston measurements OVER the cylinder deck. Henceforth, original .020" gasket + squished .015" gasket = .035" new base gasket.
Torqued her down and remeasure the piston to cylinder decking... All is good!
OMR
NOTE: Don't get whacked up on the dial readings, this was only to show the setups for discussions with Plummen & Larry C on the correct setup for measuring the piston edge to decking height differences. Thanks my brothers...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
