- Thank you received: 109
OMR: '76 KZ900 Restoration/Modification
- mark1122
- Keep twisting it
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
- Thank you received: 225
Pistons, Wiseco 1015cc (70mm). New heavy duty cylinder studs where installed (bitch to get out), no problem with oil passages... All new Liska timing parts (gears, sprockets, chains rubber etc...)
BTW... Scuffed, adhesion promoter, etched primer and shot gloss back last night on the head light shell. :evil: Sweeeet! It's really going to look good with the chromed outer ring and base/neck bottom anchor chromed...
I'll supply images tonight...
Also, I changed the front brake distribution/front brake switch... Images tonight... :evil:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Royal1MC
- Is it just me, or is it just great to be on a KZ
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
- Old Man Rock
I decided to try out something... Not sure about it but it will prevent rocks from being flung into the electrical modules and battery...
Actually I think it looks like crap.... :dry: Rear tire hugger in the future...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzr750r1
- Thank you received: 9
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- Bad Kaw
- Flying Squirell
- Thank you received: 13
Cool "go fast" parts!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
- mark1122
- Keep twisting it
Have u thought about the tail light area yet?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
You mean the Radii integrated or under seat area?
If under seat, probably just some aluminum flat plate...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mark1122
- Keep twisting it
This is with the tag under the lt.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
this is how it looks now.
I think your looks good. I'm just trying to point out the short comings of the tag up under the lt. I think it looks better up tight but it is more form than function, if u know what I mean.
By the way, how do u get muti pic in 1 post ,like u did above?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
I take all my pictures in high resolutions. Then in MicroSoft Paint application, I stretch/skew to 12 x 12 then just paste all the images into one, jpeg image.
I believe the Radii tail light is shorter than yours in height so I should be all right. It also seems I have more clearance with the J link mono shock then the dual shocks. The license plate will attach directly under the license plate on the buffed plate, so I should end up with 6-8" of clearance to the tire.
Until I get this project completed and the bike registered, not much to do about it now, I'll look at it more carefully later on. Thanks for the tip...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
