OMR: '76 KZ900 Restoration/Modification
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Re: OMR: '76 KZ900 Restoration/Modification
14 Sep 2008 21:18
#237185
Fantastic!
Thanks for the details.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 Sep 2008 05:05
#237334
Nice to see things are moveing forward for u. Great job.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
20 Sep 2008 19:16
#237957
Another update... Clutch cover modified for the 13.5mm offset cc sprocket (Chain Oil Pump mount ground down and sides cut out for chain clearance).
Clutch cable adjustments completed to service manual specs, clutch release and push rod assembly cleaned and greased for strong and smooth operation...
ZX-9 extension figured out using another HEX coupler (from good old ACE hardware)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
21 Sep 2008 13:33
#238051
Nice application on the rear-sets. Are they a 'factory' rearset off something, like a ZX9R, 7R, or something?
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
  • Old Man Rock
21 Sep 2008 15:24
#238062
I finally figured these out, they're a 1995 ZX-9 rear set...
I purchased for $40...Cleaned and buffed= looks brand new...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
21 Sep 2008 15:28 - 21 Sep 2008 15:29
#238064
Just another update...
As you may have followed, the front end is from a 2005 ZX6R (636) so since I won't be using the KZ900 instrument cluster I had to figure a way for the ignition key.
Well, had a wild hair up may ass today and this is what I came up with.
Basically, cut a 1/3 off a 2" piece of aluminum pipe I had, fabbed a top out of 1/8" aluminum plate, brazed them together and buffed out... Fairly simple but functional.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 21 Sep 2008 15:29 by Old Man Rock.
  • KawiConvert
  • KawiConvert's Avatar
21 Sep 2008 16:40
#238087
I like the ignition cover, I have been wondering what to do with mine and that one looks pretty good. B)
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
21 Sep 2008 18:38
#238097
Oh yeah, that'll definately work. I thought I recognized those pegs, I have a set myself...went with the 9Rs b/c at the time they had the most rubber-damping of the sets that I was considering.
You're bike is coming along quite nicely.
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
  • PLUMMEN
  • PLUMMEN's Avatar
21 Sep 2008 22:15
#238125
i hate looking at your project,it takes me hours to get my tongue and my eyes back in my head not to mention the drooling plays hell on my keyboard!:woohoo:
  • Old Man Rock
25 Sep 2008 18:48 - 26 Sep 2008 04:49
#238680
Update: Head light mounting bracket on 50mm fork tubes...
In reviewing numerous websites and magazines, I found head light mounting bracket pricing to be somewhat high for what you got. So I figured what the hell, I'd make my own...
Off to ACE hardware to pick up some 1/8" x 1 1/4" aluminum flat strip plate ($15) and a 1 1/2" ID (1 13/16" O.D. = 1.8" = 50mm) steel pipe ($4) for bending the aluminum around...
Here's the results....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 26 Sep 2008 04:49 by Old Man Rock.
  • PLUMMEN
  • PLUMMEN's Avatar
26 Sep 2008 03:27
#238721
crap,there goes another keyboard!:blink: :woohoo: quite the little fabricator you are sir!B)
  • Old Man Rock
26 Sep 2008 05:09 - 26 Sep 2008 05:11
#238729
Well thank you...
I have seen other brackets for ~ $80 but they just weren't fitting the theme I had in mind. For others that did, I found the costs somewhat crazy for what you got. I mean damn it, it's a headlight bracket for Christ sakes...
As can be reviewed in the attached image, $190...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 26 Sep 2008 05:11 by Old Man Rock.
