OMR: '76 KZ900 Restoration/Modification
  • timebomb33
  • timebomb33's Avatar
Re: OMR: '76 KZ900 Restoration/Modification
26 Nov 2008 16:37
#249480
jumping the gun a bit aren't you, you haven't even got the motor together and and you want to make the sparks fly , a bit premature aren't we.but it does look good you should come up here and wire my next project. ill let you know when i'm ready.
I THINK MY POWERBAND BROKE
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
26 Nov 2008 16:51
#249483
hahahhaha... well shit, I have to get er done anyways and since I don't have the head back yet I have to keep busy or I'll go friggin nuts. Besides, everything else is done!
Seriously, once I get the head back, install it with timing components, check, adjust, verify valve clearances (replace shims as required), install the carbs and tune, put the pipe on and adjust verify the timing. Then ajdust jets as required.
Basically, this old girl is ready to be fired up soon.
BTW all, the head delay IS NOT due to LARRY C...
Actually, Larry saved my ass big time where he noticed the brand new camshafts had defects that I just didn't/wouldn't have recognize... But he sure did and WebCam has already acknowledged, provided apologies and re-cut new cams for my project.
Again, Thanks big time Larry for within a month or two I would have ended up with metal shavings in my pistons... Guess what happens then... I would have been totally bummed!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
26 Nov 2008 19:33
#249524
you might want to leave the coils off just run the wiring to give you a little working room getting the top of motor back together,dont forget the dreaded valve cover install.B)
  • Old Man Rock
27 Nov 2008 11:20
#249609
While waiting for the bird to cook, having some fun to see where she's at....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
27 Nov 2008 11:34
#249612
:laugh:
  • Old Man Rock
27 Nov 2008 12:58
#249623
Just for you Grass Hopper... :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
27 Nov 2008 14:09
#249629
Why is there a gap under the front of the seat? Is it not mounted yet?:side:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
27 Nov 2008 14:54
#249636
Unfortunately yes, ... just sat the seat on there for the image.
The mount modification is already completed but it has been raining here so quickly thew it on there for the picture...
Thanks for noticing that Mark...hahahahahaha :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
06 Dec 2008 22:53
#251200
Chuggin' right along. This is a great project. Good for the motorcycle spank-bank.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • Old Man Rock
28 Dec 2008 07:14
#255066
Just an update....
Received the head work (valve/seals/guides/P&P) back from Larry C.... Thanks again Larry... B)
On to Cam degreeing....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
30 Dec 2008 15:25 - 31 Dec 2008 07:33
#255422
Cam Degreeing Update:
All is good... Cam degreeing all finished, intake finalized at 104.25 and exhaust at 104.5... Cam lobe center was depicted at 105.....
Shims came out within Kawi specification .05 to .10mm....
Valve Lifter Clearance:
Intake # 1 # 2 # 3 # 4
.1mm .09mm .1mm .1mm
Exhaust # 1 # 2 # 3 # 4
.1mm .1mm .1mm .1mm
I installed shims 230's on the exhaust side and the 235's on the Intake side.
I wrote a tutorial for Cam Degreeing with images for this process, should be able to finalize by next week or so and I'll post...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 31 Dec 2008 07:33 by Old Man Rock.
  • PLUMMEN
  • PLUMMEN's Avatar
30 Dec 2008 19:09
#255454
wheres the assembly lube on the valvetrain parts and cam lobes and bearings?top of the motor is gonna be dry when you start cranking it over!:(
